Hi
I’m running haproxy 2.4 and when the haproxy is configured in tcp mode i get a high cpu usage.
Example:
Running the stress tool to generated arround 30k connections:
./pst -c 100000 -r 100000 -u urlist.txt -p http://192.168.58.13:3128,
The cpu usage in all haproxy process spikes to near 100% and the load is 4+.
Running the same test on http mode.
The cpu usage is around 10% on each process and the load is 1.20.
I also try use to nbthread instead nbproc but get the same results.
Also, this problems continues on haproxy 2.5
Config file in HTTP mode:
# 1,5
# CPU(s) 11
log 127.0.0.1 local0
maxconn 200000
nbproc 11
cpu-map 1 0
cpu-map 2 1
cpu-map 3 2
cpu-map 4 3
cpu-map 5 4
cpu-map 6 5
cpu-map 7 6
cpu-map 8 7
cpu-map 9 8
cpu-map 10 9
cpu-map 11 10
uid 0
gid 0
chroot /tmp
pidfile /var/run/haproxy.pid
stats socket /var/run/haproxy.stat mode 600 level admin
stats bind-process 1
# debug
# quiet
log-format HASTATS:::%{+Q}o:::client_ip=%ci:::client_port=%cp:::datetime_of_request=[%tr]:::frontend_name_transport=%ft:::backend_name=%b:::server_name=%s:::time_to_receive_full_request=%TR:::Tw=%Tw:::Tc=%Tc:::response_time=%Tr:::active_time_of_request=%Ta:::status_code=%ST:::bytes_read=%B:::captured_request_cookie=%CC:::captured_response_cookie=%CS:::termination_state_with_cookie_status=%tsc:::actconn=%ac:::feconn=%fc:::beconn=%bc:::srv_conn=%sc:::retries=%rc:::srv_queue=%sq:::backend_queue=%bq:::captured_request_headers_default_style=%hr:::captured_response_headers_default_style=%hs:::server_ip=%si:::server_port=%sp:::frontend_name=%f:::http_method=%HM:::http_request_uri_without_query=%HP:::http_request_query_string=%HQ:::http_request_uri=%HU:::bytes_uploaded=%U:::ssl_ciphers=%sslc:::ssl_version=%sslv:::%[capture.res.hdr(0)]
maxconn 200000
frontend ddsds
bind :3128 name ddsds
capture request header Host len 1024
capture request header Content-Type len 1024
capture request header User-Agent len 1024
capture request header Referer len 1024
capture request header X-Forwarded-For len 1024
capture response header Content-Type len 1024
capture cookie Cookie_2 len 100
http-request set-header mode mode:tcp
http-request capture hdr(mode) len 10
# http-keep-alive: * 1 *
timeout http-keep-alive 15000
option prefer-last-server
no option httpclose
option http-tunnel
timeout client 15000
timeout http-request 50000
timeout queue 50000
default_backend default_ddsds
no option httpclose
option http-tunnel
timeout connect 4000
timeout queue 50000
server normal_port 192.168.58.12:50877 weight 1 maxconn 10000 check inter 60000 rise 2 fall 3 source 192.168.58.13
# ddsds no result
frontend admin_page
bind 127.0.0.1:64741
stats refresh 10s
stats uri /stats
Config file in TCP mode:
# 1,5
# CPU(s) 11
maxconn 200000
nbproc 11
cpu-map 1 0
cpu-map 2 1
cpu-map 3 2
cpu-map 4 3
cpu-map 5 4
cpu-map 6 5
cpu-map 7 6
cpu-map 8 7
cpu-map 9 8
cpu-map 10 9
cpu-map 11 10
uid 0
gid 0
chroot /tmp
# debug
# quiet
maxconn 200000
frontend ddsds
option http-tunnel
timeout queue 50000
option http-tunnel
timeout queue 50000
# ddsds no result
frontend admin_page
stats refresh 10s
stats uri /stats
Anyone can help me to fix this issue.
Thanks in advance.
