Hello Everyone!
I had been been testing an HAPROXY configuration with 2 Exchange 2013 servers. Between the documentation and some help from this forum, I was able to get a functional load balancer working for all exchange services. I ran a pilot test with roughly 30 users (Various versions of outlook and ActiveSync on both android and apple devices). Everything went well and I really didn’t receive and complaints or issues.
We’ve gone live with the configuration (full user base is roughly 300 users). While there have been no specific issues, I have noticed that Outlook clients intermittently take a bit to connect as well as pulling up things like shared calendars.
Everything on the Exchange side checks out. The only thing I’ve noticed is that (as the title says) There are a high number of connection resets during transfers. I feel like the volume of resets isn’t normal but I’m not sure what else I can adjust.
I have attached my configuration below, any assistance would be greatly appreciated!
log 127.0.0.1 local0 info
maxconn 10000
quiet
ssl-default-bind-ciphers ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-DSS-AES128-GCM-SHA256:kEDH+AESGCM:ECD$
ssl-default-server-ciphers ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-DSS-AES128-GCM-SHA256:kEDH+AESGCM:E$
timeout connect 60000ms
timeout client 30000ms
timeout server 60000ms
timeout check 60000ms
stats hide-version
stats show-node
stats auth admin:password
stats uri /stats
frontend unsecured 1.2.3.4:80
redirect location https://mail.domain.com/owa
frontend fe_ex2013
bind *:443 ssl crt /etc/ssl/certs/exchange_certificate
acl autodiscover url_beg /Autodiscover
acl mapi url_beg /mapi
acl rpc url_beg /rpc
acl owa url_beg /owa
acl eas url_beg /microsoft-server-activesync
acl ecp url_beg /ecp
acl ews url_beg /ews
acl oab url_beg /oab
use_backend be_ex2013_autodiscover if autodiscover
use_backend be_ex2013_mapi if mapi
use_backend be_ex2013_rpc if rpc
use_backend be_ex2013_owa if owa
use_backend be_ex2013_eas if eas
use_backend be_ex2013_ecp if ecp
use_backend be_ex2013_ews if ews
use_backend be_ex2013_oab if oab
default_backend be_ex2013
option httpchk GET /autodiscover/healthcheck.htm
0ption log-health-checks
http-check expect status 200
server Cas1 10.10.10.31:443 check ssl inter 15s verify required ca-file /etc/ssl/certs/ca-bundle.crt
server Cas2 10.10.10.28:443 check ssl inter 15s verify required ca-file /etc/ssl/certs/ca-bundle.crt
option httpchk GET /mapi/healthcheck.htm
option log-health-checks
option httpchk GET /rpc/healthcheck.htm
option httpchk GET /owa/healthcheck.htm
option httpchk GET /microsoft-server-activesync/healthcheck.htm
option httpchk GET /ecp/healthcheck.htm
option httpchk GET /ews/healthcheck.htm
option httpchk GET /oab/healthcheck.htm
backend be_ex2013
listen smtp *:25
server Cas1 10.10.10.31:25 check
server Cas2 10.10.10.28:25 check
