Is it possible to combine multiple backend (like in fe-b frontend below) on HAProxy 1.8 so that the servers from both backend can be used within frontend without repeating the servers on backend.
frontend fe-a
use_backend be-test-1
frontend fe-b
use_backend >>>### USE SERVERS FROM BOTH be-test-1 AND be-test-2 ###<<<
backend be-test-1
server srv-1 111.111.111.1:4567 check
server srv-2 111.111.111.2:4567 check
backend be-test-2
server srv-1 222.222.222.1:4567 check
server srv-2 222.222.222.2:4567 check
