Multiple Profiles of Configuration for BE/FE
One question:
Is haproxy capable of working with multiple frontend/backand profiles?
Example:
-> if the request is from the network 192.168.1.X it sends to the configurations of frontendX / backendX;
-> And if the requests are from the 192.168.1.Y network, then it directs to the frontendY / backendY configurations.
Can you do that?
Nope, HAProxy can’t do that.
The best for you is to chain 2 set of FE / BE: the first FE does the routing to a BE based on client IP. This BE points to your application FE with your own settings.
IE:
frontend myapp
  use-backend be1 if { src 192.168.1.X }
  use-backend be2 if { src 192.168.1.Y }
backend be1
  server fe1 127.0.0.1:81
backend be2
  server fe2 127.0.0.1:82
frontend fe1
  default_backend myapp1
frontend fe2
  default_backend myapp2
backend myapp1
  server srv1 xxxxx
backend myapp2
  server srv1 xxxxx
