I’ve been using the following formula:
# SNI dmarc
frontend port443-raw from tcpees
bind :443 alpn h2
bind :::443 alpn h2
default_backend loopback-main
# main frontend
frontend main from httpees
bind /haps/main.socket name main accept-proxy ssl crt fullchain.pem alpn h2,http/1.1
http-request set-var(txn.txnpath) path
acl auto var(txn.txnhost) -m str -i sub1.domain1.tld
acl auto var(txn.txnhost) -m str -i sub2.domain1.tld
acl sub3 var(txn.txnhost) -m str -i sub3.domain1.tld
http-response set-header Content-Security-Policy "object-src…" if auto
http-response add-header Content-Security-Policy "script-src…" if auto
http-response add-header Content-Security-Policy "img-src…" if auto
http-response set-header Content-Security-Policy "obj…" unless auto
use_backend %[req.hdr(Host),lower] if auto || sub3 || …
# looparound backend
server main /haps/main.socket send-proxy-v2-ssl-cn
# most backends are very similar to this
backend sub1.domain1.tld from httpees
option httpchk
http-check send meth OPTIONS uri / ver HTTP/1.1\r\nHost:\ sub1.domain.tld
use-server std if !{ ssl_fc }
use-server tls if { ssl_fc }
server std sub1.domain.tld:80 check inter 12s observe layer7 error-limit 10 on-error fastinter
server tls sub1.domain.tld:443 ssl check inter 12s observe layer7 error-limit 10 on-error fastinter
It works flawlessly for header manipulation if based on hostname, such as above. I tried it on a pathname…
acl path var(txn.txnpath) -m sub -i /examplepath
http-response set-header Content-Security-Policy "obj…" if path
and it wouldn’t work. The variables made it error silently. Later when I ditched the variables and using the “acl url_static path_beg /static” construction I finally got a message that the way I was doing it would never match. It didn’t say why, though. (I added an ACL for the hostname too, BTW, and then not)
Adding them on the backends I think would work, but since most are mass-added on the frontend, I’d have to single them out resulting in very complicated rules or remove them altogether and add them to every single backend making even bigger the already-1100plus-line config file.
How can I add response header based on a path?
