Hi everybody,
I want to route my requests according to its final destination regarding both the dns of the endpoint targeted or/and some part of the url path. I have not found satisfying results using the following config :
I have tried path_beg, path_end, path_sub with the following config :
bind *:8080
acl admin_url path_sub admin
use_backend srvs_app1 if admin_url
backend srvs_app1
server host1 HOST1_IP:PORT1 check
server host2 HOST2_IP:PORT2 check
and this one too :
frontend frontend-base
bind 0.0.0.0:4030
acl is_monip path_sub -i ip
use_backend app if is_monip
backend backend-base
balance random two
server web-01 HOST1_BCK:PORT1_BCK check
server web-02 HOST2_BCK:PORT2_BCK check
backend app
balance random two
server web-03 HOST1_APP:PORT1_APP check
server web-04 HOST2_APP:PORT2_APP check
path_sub does not seam to work, any advise ?
