Hello All,
Greetings !
I have a very basic setup and am trying to use haproxy as reverse proxy to route requests to different servers based on my urls.
log 127.0.0.1 local2 info
pidfile /run/haproxy.pid
Default SSL material locations
bind *:1936
stats uri /
stats hide-version
stats auth admin:admin
frontend http
bind *:5000
default_backend srvc_default
acl workspace path_end -i /cb
use_backend srvc_workspace if workspace
#http-request set-path / if workspace
server server1 myapp
cookie QPP prefix
#server qppworkspace qppworkspace:3000
server qppworkspac google.com
listen default
bind *:4242
My sample configuration is shown above.
If I hit the url server/cb, it takes me to the desired server but appends /cb to that url, so essentially I get an error 404 as myserver/cb does not exist.
I just want to route the request if my path contains /cb but /cb should not be part of the final url that reaches my back end.
Thanks again for helping
Regards,
Harneet
