How does Ulimit-n computation works?
I got a haproxy 1.8 vanilla alpine docker image running with maxconn = 2000
curl -s http://host:port/stats | grep -E 'limit|maxcon'
<b>system limits:</b> memmax = unlimited; ulimit-n = 4015<br>
<b>maxsock = </b> 4017; <b>maxconn = </b> 2000; <b>maxpipes = </b> 0<br>
Sometimes I get the following Warning in my logs:
[WARNING] 0/0 (0) : [/usr/local/sbin/haproxy.main()] FD limit (4015) too low for maxconn=2000/maxsock=4017. Please raise 'ulimit-n' to 4017 or more to avoid any trouble.
I find it very odd since I read this in haproxy doc:
ulimit-n
Sets the maximum number of per-process file-descriptors to . By
default, it is automatically computed, so it is recommended not to use this
option.
here is the version I use:
# /usr/local/sbin/haproxy -vv
HA-Proxy version 1.8.4-1deb90d 2018/02/08
  TARGET  = linux2628
  CPU     = generic
  CC      = gcc
  CFLAGS  = -O2 -g -fno-strict-aliasing -Wdeclaration-after-statement -fwrapv -Wno-null-dereference -Wno-unused-label
  OPTIONS = USE_ZLIB=1 USE_OPENSSL=1 USE_LUA=1 USE_PCRE=1
Built with OpenSSL version : OpenSSL 1.0.2n  7 Dec 2017
Running on OpenSSL version : OpenSSL 1.0.2n  7 Dec 2017
Built with PCRE version : 8.41 2017-07-05
Running on PCRE version : 8.41 2017-07-05
Is it a bug in haproxy or something I am doing wrong ?
Can you share you configuration? Are you sure you are starting haproxy as root?
I confirm I am running haproxy as root.
here is my simple config:
    log     127.0.0.1:<LOG_PORT> local0 warning emerg
    log     global
    option  dontlognull
    option  tcplog
    option  logasap
    log     global
    mode    http
    bind    :<STATS_PORT>
    stats hide-version
    stats refresh 15s
    stats show-node
    stats uri /stats
listen xx
    log     global
    mode    tcp
    bind    :<PORT>
    server s1 <HOST>:<PORT> check
might also be of interest:
/ # ulimit -Hn
1048576
/ # ulimit -Sn
1048576
I have the same issue with HAProxy 1.8.8
pid = 1151 (process #2, nbproc = 2, nbthread = 1)
uptime = 0d 0h14m36s
system limits: memmax = unlimited; ulimit-n = 4096
maxsock = 1000069; maxconn = 500000; maxpipes = 0
current conns = 1; current pipes = 0/0; conn rate = 0/sec
Running tasks: 1/52; idle = 100 %
Here si the conf
[root@haproxy01 ~]# cat /etc/haproxy/haproxy.cfg
# This file managed by Puppet
  chroot  /var/lib/haproxy
  cpu-map  1-2 0-1
  log  127.0.0.1 local0 debug
  maxconn  500000
  nbproc  2
  spread-checks  5
  stats  socket /var/run/haproxy.stat mode 600 level admin process 1
  stats  bind-process 1
  tune.ssl.default-dh-param  2048
  log  global
  timeout  connect 5s
And the processes look like this:
[root@haproxy01 ~]# ps aux | grep hapr
root      33842  0.0  0.0 178124  4520 pts/1    S+   may15   0:00 ssh haproxy02
root      35678  0.0  0.1  81156 10120 ?        Ss   may15   0:00 /usr/sbin/haproxy -Ws -f /etc/haproxy/haproxy.cfg -p /var/run/haproxy.pid
root      35682  0.3  0.7 161576 63148 ?        Ss   may15   8:28 /usr/sbin/haproxy -Ws -f /etc/haproxy/haproxy.cfg -p /var/run/haproxy.pid
root      35683  0.3  0.7 161936 63568 ?        Ss   may15   8:33 /usr/sbin/haproxy -Ws -f /etc/haproxy/haproxy.cfg -p /var/run/haproxy.pid
root     111407  0.0  0.0 112660   980 pts/0    S+   11:41   0:00 grep --color=auto hapr
It seems the processes started by Systemd, Supervisord or (maybe) any other init system don’t take those values set globally.
If I set in:
[root@haproxy03 ~]# vi /etc/systemd/system/multi-user.target.wants/haproxy.service
this:
[Service]
LimitNOFILE=infinity
Then I get:
for what it’s worth: I use the master worker mode
I see there is a FD_SETSIZE variable in Makefile… so I am wondering whether there is no way to get higher ulimit -n:
TARGET_CFLAGS = -fomit-frame-pointer -DFD_SETSIZE=65536 -D_REENTRANT -D_XOPEN_SOURCE=500 -D__EXTENSIONS__
Since I run this through systemd I have also set up the following:
[root@haproxy03 ~]# cat /etc/systemd/system/haproxy.service.d/90-limits.conf
# This file managed by Puppet - DO NOT EDIT
[Service]
LimitNOFILE=1000100
Those are the /var/log/messages:
un 14 11:47:14 haproxy03 systemd: Starting HAProxy Load Balancer...
Jun 14 11:47:14 haproxy03 haproxy: [WARNING] 164/114714 (4255) : [/usr/sbin/haproxy.main()] Ca
nnot raise FD limit to 2000272, limit is 65536.
Jun 14 11:47:14 haproxy03 haproxy: [WARNING] 164/114714 (4255) : [/usr/sbin/haproxy.main()] FD
 limit (65536) too low for maxconn=1000100/maxsock=2000272. Please raise 'ulimit-n' to 2000272
Jun 14 11:47:14 haproxy03 systemd: Started HAProxy Load Balancer.
