Hi guys,
i was working on configuring 995 port for enabling mail client access through 995 , 110 port is working fine with mail client (thuderbird).below mentioned my both configuration of frontend and backend of both ports , please help me to fix this issue.
frontend conf of 110 & 995
frontend sa_frontend_pop3
bind *:110
#ssl crt /etc/nginx/certificates/ssl.d no-sslv3
default_backend sa_pop3
frontend sa_frontend_pop3s
bind *:995 ssl crt /etc/nginx/certificates/ssl.d/
default_backend sa_pop3s
Backend conf of 110 & 995
backend sa_pop3
balance source
option log-health-checks
server mail_sa_srv1 xx.xx.xx.x:110 check
backend sa_pop3s
balance source
server mail_sa_srv1 xx.xx.xx.x:995 check
995 port is not working error from client is unable to find your mail settings, is there any mistake or do i need to any additional configuration ?
Thanks in advance
