How to deploy HA Proxy as a pod in Kubernetes
Hi Team,
Our Jitsi application is running on Kubernetes and from Jitsi community I got to know that we need HA proxy for Jitsi load balancing.
Hence I need help if you can guide me, Is there is any HA proxy helm chart is available which I can use and configure it in Kubernetes Cluster deployment ?
lmgtfy:
There is a separate section for the community edition.
but then how we will set the frontend and backend config if I go with this ingress controller.
