How to disable backend check?
I have a haproxy (1.8.19) with a backend containing a single server node.
The server was not accessible for few minutes and haproxy considered this server as unavailable.
Feb 13 02:53:54 ip-172-31-42-147 haproxy[27944]: Server node1 is DOWN, reason: Layer4 timeout, check duration: 2002ms. 0 active and 0 backup servers left. 0 sessions active, 0 requeued, 0 remaining in queue.
Feb 13 02:53:54 ip-172-31-42-147 haproxy[27944]: Servernode1 is DOWN, reason: Layer4 timeout, check duration: 2002ms. 0 active and 0 backup servers left. 0 sessions active, 0 requeued, 0 remaining in queue.
Feb 13 02:53:54 ip-172-31-42-147 haproxy[27944]: backend backend has no server available!
*Feb 13 02:53:54 ip-172-31-42-147 haproxy[27944]: backend backend has no server available!
The server was unavailable at 02:53:54 and still at 09:32:00 until we’ve restarted haproxy.
Is there a way to disable http check or to set a periodic recheck of the server health?
Thanks.
Remove the check keyword to disable health checking. Configure health check intervals with inter.
Thanks for your answer.
I’d though that the check was part of the “ssl no verify”
Seb.
It is not, no.
