Hi there,
I’m using HAP on and off for a bit now and now I’m trying confgure DDoS protection per frontend, to block a connection for 5 mints, if it receives more than 200 requests per second from the same source IP, taking the fact into account that mutiple source-ips can/will be used to launch the attack. I looked into various blogposts and posts in the Internet and more I see I get more confused about the correct counfig that I need to have for my purpose.
Below are the all the configurations that I have collected so far:
backend ip_rates_abuse
stick-table type ip size 200k expire 5m store gpc0,conn_cur,conn_rate(10s),http_req_rate(10s),http_err_rate(10s)
frontend fe_dev_mydomain_com
## ----- TCP Layer DDoS protection ------------ ##
timeout tarpit 15s
tcp-request content reject if { src_conn_rate(ip_rates_abuse) ge 200 }
tcp-request content reject if { src_conn_cur(ip_rates_abuse) ge 500 }
tcp-request content reject if { src_get_gpc0(ip_rates_abuse) gt 0 }
tcp-request session track-sc0 src table ip_rates_abuse
acl too_many_reqs sc_http_req_rate(0) gt 200
http-request set-var(txn.ratelimited) str(RATE-LIMITED) if too_many_reqs
http-request capture var(txn.ratelimited) len 12
http-request deny deny_status 429 if too_many_reqs
use_backend be_waf if no_tarpit || tarpit_max_capacity
and then in the backend:
backend be_waf
acl too_many_clicks sc1_http_req_rate gt 200
acl mark_as_abuser sc0_inc_gpc0(ip_rates_abuse) gt 0
tcp-request content track-sc1 src table ip_rates_abuse
tcp-request content reject if too_many_clicks mark_as_abuser
I’m pretty sure I didn’t understand a number of things but did I do it right? Looks like a bit overdoing to me and seems not working either. Can anyone suggest me the minimum config that I should have to achieve my goal pls?
Not sure if it helps in this context but this is how my HAP is configured:
The HAP is behind a AWS Network Load-balancer (NLB), running in TCP mode
Multiple sites/domains come in through an universal frontend (
fe_https) and then based on the domain, it’s forwarded to the domain specific backend, like this:frontend fe_https mode tcp option tcplog bind *:443 tfo accept-proxy tcp-request inspect-delay 5s tcp-request content accept if { req.ssl_hello_type 1 } use_backend be_dev_mydomain_com if { req.ssl_sni -i -m dom dev.mydomain.com } use_backend be_stg_mydomain_com if { req.ssl_sni -i -m dom stg.mydomain.com } default_backend be_tarpit -
Those backends then forward the connection to the localhost on a dedicated port per associated domain-specific frontend, like this:
backend be_dev_mydomain_com mode tcp option tcp-check option tcp-smart-connect timeout queue 15s server dev_mydomain_com 127.0.0.1:9001 check send-proxy-v2 -
The forntend(s) has all the necessary config to do stuff like TLS offloading, DDoS protection etc. and then it uses an universal backend, to forward the connection to AWS Application Load-balancer (ALB):
frontend fe_dev_mydomain_com bind 127.0.0.1:9001 tfo accept-proxy ssl ... option http-buffer-request option forwardfor except 127.0.0.1 ...... default_backend be_tarpit use_backend be_waf if no_tarpit || tarpit_max_capacity backend be_waf option httpchk http-check expect ! rstatus ^5 server aalibc <server_addr>:8080 check resolvers awsdns init-addr last,libc,none
Any help will be greatly appreciated.
-S
