Hello All,
I would like to configure basic DDOS protection measures on a pair of HAProxy 1.5 servers that are behind an AWS ELB.
The ELB is in tcp mode with proxy-protocol enabled.
I have read through the internet and came accross several examples but none of them seemed to have worked.
In my current config I can finally see entries in the relevant stick-table but having problems taking action based on them.
I can see the counters go up in the table when generating loads using “ab”, but there are no denied sessions when looking at the HAProxy status page.
What am I doing wrong?
Any help would be appreciated.
frontend bits:
tcp-request connection reject if { src_conn_rate(Logger) ge 20 }
tcp-request connection reject if { src_conn_cur(Logger) ge 10 }
tcp-request connection reject if { src_get_gpc0(Logger) gt 0 }
tcp-request connection expect-proxy layer4
tcp-request content track-sc0 src table Logger
Application backend:
acl abuse src_http_req_rate(Logger) ge 10
acl flag_abuser src_inc_gpc0(Logger)
tcp-request content reject if abuse flag_abuser
Logger backend for the stick table:
backend Logger
stick-table type ip size 100k expire 3m store conn_rate(3s),gpc0,conn_cur,http_req_rate(10s),http_err_rate(10s)
Example entries in the table:
0x85302c: key=1xx.2xx.2xx.2xx use=0 exp=169083 gpc0=91 conn_rate(3000)=0 conn_cur=0 http_req_rate(10000)=93 http_err_rate(10000)=9
0x85302c: key=1xx.2xx.2xx.2xx use=2 exp=179997 gpc0=5483 conn_rate(3000)=456 conn_cur=2 http_req_rate(10000)=1543 http_err_rate(10000)=0
