I am setting map key, value using socket. But same is not flushed to map file on disk.
This means HAProxy restart gets old load2 - 2 value and not new value 22.
How could a map be flushed to disk after set map?
Could someone please clarify as documentation is blank on flush part.
$ echo “set map /home/cloud/load.map load2 22” | sudo socat /var/run/haproxy.sock stdio
$ cat load.map
load1 10
load2 2
$ echo “show map /home/cloud/load.map” | sudo socat /var/run/haproxy.sock stdio
0x15890f0 load1 10
0x1589120 load2 22
