I can monitor HAProxy stats via
stats uri /<URI>
and
curl ../<URI>
I need to get backends info and I’ve searched such way:
echo “show backend” |
sudo socat stdio tcp4-connect:<IP>:<PORT>
but it nothing returns.
Should I define similar section in the HAProxy configuration before using such .. API?
Otherwise there’re no configuration issues and show backend is built-in API endpoint and there’re other problems (user/password maybe)?
So what’s the next steps I need to follow to resolve the issue?
