Hello all,
I am using haproxy as a TCP load-balancer and TLS terminator, and I am trying to measure how many connections and requests are being served per domain and backend. The weird thing is that no matter how many requests it reports for the frontends, there are always non-values for the backends.
I am watching the req_rate (47th) req_rate_max (48th) columns.
It does report a few established connections (scur, 5th column) though. The backends (that are hosted in different servers) do receive requests from haproxy.
Here is how I am getting the stats:
while true; do echo "show stat" | sudo netcat -U /run/haproxy/admin.sock | tail -n +3 | awk -F ',' '{print $1","$2","$5","$47","$48}' ; sleep 1; done
which gives (trimmed):
stats,BACKEND,0,,
vip-217,FRONTEND,1056,130,1553
vip-218,FRONTEND,0,0,0
internal-203,FRONTEND,0,0,0
internal-204,FRONTEND,0,0,0
p2p-tracker-prd,multi1,1,,
ch-nl-7,ch94,0,,
ch-nl-7,ch95,0,,
ch-nl-7,BACKEND,0,,
ch-nl-8,ch27,3,,
ch-nl-8,ch28,2,,
I would expect more connections (aka: scur which is $5) too.
And in order to filter out the null values:
while true; do echo "show stat" | sudo netcat -U /run/haproxy/admin.sock | tail -n +3 | awk -F ',' '{if ($1 != "" && $2 != "" && $5 != "" && $47 != "" && $48 != "") print $1","$2","$5","$47","$48}' ; sleep 1; done
which reports only the frontends, because the backend have empty values for req_rate and max_req_rate:
vip-217,FRONTEND,1016,164,1553
The haproxy.conf has:
bind 10.0.19.3:8888
stats uri /haproxy?stats
stats auth user:pass
stats refresh 5s
acl network_allowed src 10.0.0.0/16
tcp-request connection reject if !network_allowed
and
master-worker
nbthread 28
maxconn 1000000
tune.ssl.cachesize 5000000
no log
no log
timeout client 500000
timeout server 500000
maxconn 300000
Sample frontend conf:
frontend vip-217
bind pubipv4:80
bind pubipv4:443 ssl crt /etc/haproxy/certs transparent
bind pubipv6:80 transparent
bind pubipv6:443 ssl crt /etc/haproxy/certs transparent
maxconn 300000
timeout client 370000
compression algo gzip
compression type text/plain text/css application/json application/javascript text/xml application/xml application/xml+rss text/javascript
# ... some ACLs here like : ....
acl isAdminAPI hdr(host) -i domain1
acl isAdminAPIStage hdr(host) -i domain2
acl isAdminAPIBeta hdr(host) -i domain3
acl isDateToken urlp(dateToken) -m found
use_backend back1 if isAdminAPI
use_backend back2 if isAdminAPIStage
use_backend back3 if isAdminAPIBeta
use_backend back4 if isDateToken
use_backend %[req.hdr(host),lower,map_dom(/etc/haproxy/domain2backend.map,bk_default)]
sample backend conf:
backend back1
option splice-auto
option abortonclose
option http-server-close #SCL: server close
timeout server 90000
errorfile 408 /dev/null
balance source
hash-type consistent
server server1 10.0.18.1:8080 check
server server2 10.0.19.9:8080 check
Any ideas to troubleshoot this?
