I have added option smtpchk in the backend section. It is checking at every second. I don’t want to do that at every second. I want to run a health check every 10 seconds. How can I do that?
Eg:
timeout check 10s
Is the above configuration option correct?
@lukastribus Is this correct way to add these into backend section for SMTP health check?
Eg:
backend smtp-backend-mail
option smtpchk
max-spread-checks 10000
balance source
hash-type consistent
stick-table type ip size 20k
stick on src
server IP:25 check on-marked-down shutdown-sessions
No, use the configuration I suggested, which is the inter keyword.
server IP:25 check inter 10s on-marked-down shutdown-sessions
Thanks for the reply. @lukastribus Will this have any side effects? This only affects the health check right?
The one and only use-case for this option is to configure the interval between one health check and another health check, as per the documentation:
The “inter” parameter sets the interval between two consecutive health checks to milliseconds.
Unless you modify other unrelated parameters (like timeout check), there is not side effect.
