I am new to haproxy and wanted to give it a try on centos 7.6.
I want to use haproxy to do the failover of a redis instance, which is located behind stunnel to enable tls on redis. On producer side I am using fielebeat and metricbeat which sends data tls encrypted to redis.
Stunnel and redis are located on the same box.
So my chain looks like this:
producer -> (TLS) -> haproxy (TLS passthrough) -> (TLS) -> stunnel -> redis.
Without encryption it healthcheck and connection via redis-cli from external to redis via haproxy is working fine.
That is the config for that:
defaults REDIS
timeout connect 3s
timeout server 6s
timeout client 6s
frontend ft_redis
bind 0.0.0.0:16380 name redis
default_backend bk_redis
backend bk_redis
option tcp-check
tcp-check connect
tcp-check send PING\r\n
tcp-check expect string +PONG
tcp-check send info\ replication\r\n
tcp-check expect string role:master
tcp-check send QUIT\r\n
tcp-check expect string +OK
server server1 localhost:7000 check inter 1s
server server2 localhost:7001 check inter 1s
Now I want to do the same, but via accessing the stunnel ports (where I need to connect via TLS).
I changed the two server lines to:
server server1 localhost:7100 check-ssl inter 1s ssl verify none
server server2 localhost:7101 check-ssl inter 1s ssl verify none
But looks like something is wrong. The healthcheck does not come back. The backend lines in stats are gray without any status.
Do you have any ideas how to solve the issue?
Thanks a lot, Andreas
