How to replace domain in haproxy request?
is it possible to change/rewrite/replace the domain name in the request before you pass it through to the backend server?
I have 1 frontend:
frontend https-dev
        maxconn 2000
        option forwardfor header X-Real-IP
        http-request set-header X-Real-IP %[src]
        default_backend be-dev-cdn
        # BEGIN CORS
        http-response set-header Access-Control-Allow-Origin "*"
        http-response set-header Access-Control-Allow-Headers "Origin, X-Requested-With, Content-Type, Accept, Authorization, JSNLog-RequestId, activityId, applicationId, applicationUserId, channelId, senderId, sessionId"
        http-response set-header Access-Control-Max-Age 3628800
        http-response set-header Access-Control-Allow-Methods "GET, DELETE, OPTIONS, POST, PUT"
        # END CORS
        bind *:443 ssl crt domain.pem
        # set X-SSL in case of ssl_fc <- explained below
        http-request set-header X-SSL %[ssl_fc]
And 1 backend with multiple hosts:
backend be-dev-cdn
        server dev-cdn01.domain.com 192.168.101.1:80 check
        server dev-cdn02.domain.com 192.168.101.2:80 check
        server dev-cdn03.domain.com 192.168.101.3:80 check
        server dev-cdn04.domain.com 192.168.101.4:80 check
        server dev-cdn05.domain.com 192.168.101.5:80 check
The user would input the domain www.domain.com and I would then rewrite/replace this domain to a new domain name based on the backend server to which the request is forwarded. For example: www.domain.com → haproxy → backend server dev-cdn05.domain.com; rewrite the request.
My goal is that I would just like to route the requests through haproxy server but not the response
Is this possible with haproxy?
In your backend section, you can add
http-request set-header Host otherdomain.com
If needed you can add a condition, for example :
http-request set-header Host otherdomain.com if { req.hdr(host) -i mydomain.com }
yes…this works if you are replacing 1 domain. If you look at my example I have configured 5 backend servers and would like to change the domain to the “domain” of the selected backend server.
Example:
selected backend server: dev-cdn01.domain.com change domain to dev-cdn01.domain.com
selected backend server: dev-cdn02.domain.com change domain to dev-cdn02.domain.com
selected  backend server: dev-cdn03.domain.com change domain to dev-cdn03.domain.com
selected backend server: dev-cdn04.domain.com change domain to dev-cdn04.domain.com
selected backend server: dev-cdn05.domain.com change domain to dev-cdn05.domain.com
BR
I don’t know if it’s possible with different servers within the same backend. I mad some test (with : http-request set-header Host %s) and when Haproxy modify the headers, it seems it doesn’t know yet the server it will use.
Withe several backends named regarding the hos you want you can do
http-request set-header Host %b
Maybe with dynamic mapping but not very sure.
if you change the server name to match the domain you are sending it to, then you can use:
http-send-name-header  host
which will send the server’s “name” as the “Host” header.
That will set the host to the name of the backend, which is “be-dev-cdn”
%s will give you the servername, but I"m not sure if there is a way to get the hostname of the server line.
That’s why a said he has to rename backend.
But i was not aware of the http-send-name-header option. This seems the right way to do it.
