How to setup MITM?
Hello, I am trying to configure a MITM like haproxy (to add cookies for incoming requests)
and servers are actually other HTTP proxies.
This is how I am generating the .pem file -
openssl req -new -newkey rsa:2048 -sha256 -days 365 -nodes -x509 -extensions v3_ca -keyout haproxy-ca-key.pem -out haproxy-ca-cert.pem -subj “/C=GB/ST=London/L=London/O=Global Security/OU=IT Department/CN=websiteIamtryingtoMITM.com
**websites like google.com etc.
Followed by -
cat haproxy-ca-cert.pem haproxy-ca-key.pem >> mysite.pem
My configuration -
    ssl-default-bind-ciphers ECDH+AESGCM:DH+AESGCM:ECDH+AES256::RSA+AES:RSA+3DES:!aNULL:!MD5:!DSS
        log     global
        mode    tcp
        option  httplog
        option  dontlognull
        timeout client  50000
        timeout server  50000
frontend front
    bind 0.0.0.0:8443
    bind 0.0.0.0:443 ssl crt /etc/haproxy/certs/mysite.pem crt-ignore-err all
    default_backend web_servers
backend web_servers
 server Node1009 proxy:1009 ssl verify none
 server Node1010 proxy:1010
output of haproxy -vv
HA-Proxy version 2.2.3-2 2020/09/09 - https://haproxy.org/
Known bugs: http://www.haproxy.org/bugs/bugs-2.2.3.html
Running on: Linux 5.8.0-29-generic #31-Ubuntu SMP Fri Nov 6 12:37:59 UTC 2020 x86_64
TARGET = linux-glibc
CC = gcc
CFLAGS = -O2 -g -O2 -fdebug-prefix-map=/build/haproxy-fB8IVI/haproxy-2.2.3=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -Wall -Wextra -Wdeclaration-after-statement -fwrapv -Wno-address-of-packed-member -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-clobbered -Wno-missing-field-initializers -Wno-stringop-overflow -Wno-cast-function-type -Wtype-limits -Wshift-negative-value -Wshift-overflow=2 -Wduplicated-cond -Wnull-dereference
OPTIONS = USE_PCRE2=1 USE_PCRE2_JIT=1 USE_OPENSSL=1 USE_LUA=1 USE_ZLIB=1 USE_SYSTEMD=1
Feature list : +EPOLL -KQUEUE +NETFILTER -PCRE -PCRE_JIT +PCRE2 +PCRE2_JIT +POLL -PRIVATE_CACHE +THREAD -PTHREAD_PSHARED +BACKTRACE -STATIC_PCRE -STATIC_PCRE2 +TPROXY +LINUX_TPROXY +LINUX_SPLICE +LIBCRYPT +CRYPT_H +GETADDRINFO +OPENSSL +LUA +FUTEX +ACCEPT4 +ZLIB -SLZ +CPU_AFFINITY +TFO +NS +DL +RT -DEVICEATLAS -51DEGREES -WURFL +SYSTEMD -OBSOLETE_LINKER +PRCTL +THREAD_DUMP -EVPORTS
Built with OpenSSL version : OpenSSL 1.1.1f 31 Mar 2020
Running on OpenSSL version : OpenSSL 1.1.1f 31 Mar 2020
Built with gcc compiler version 10.2.0
: mode=HTTP side=FE|BE mux=H1
Available services :
prometheus-exporter
Using haproxy as a proxy on firefox just returns “Secure Connection Failed” , not allowing to make an exception for unsecure certificate.
Clearly I’m doing something wrong, so please if you notice something let me know as this is becoming so frustrating.
What do I even need to do, the SSL/TLS Bridging , or the SSL/TLS Termination should do the job?
Thank you in advance!
If you want to be able to modify the HTTP headers, you have to terminate the SSL/TLS on haproxy and use http mode.
I would use terminate the TLS in the frontend, transform the request, and use a backend with TLS configuration to reach the final servers.
Thank you for the answer, but how would one configure the TLS for a backend?
Something like -
  server server1 proxyserver1:1001 ssl verify required ca-file /etc/ssl/certs/ca-certificates.crt
Yes, something like that.
