Hey Guys, I recently updated my config to use the latest ciphers and TLS1.2+ version, which should be fine for the valid traffic. However, I’m now seeing a lot of “SSL handshake failure” logs that I suspect are related to non-legitimate traffic. Is there any way to filter out or silence these logs?
hard-stop-after 12h
log syslog.example.com:514 len 4096 format rfc5424 syslog
maxconn 210000
nbthread 3
spread-checks 3
ssl-default-bind-ciphers ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305!aNULL:!eNULL:!EXPORT:!DES:!RC4:!3DES:!MD5:!PSK
ssl-default-server-ciphers ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305!aNULL:!eNULL:!EXPORT:!DES:!RC4:!3DES:!MD5:!PSK
ssl-default-server-options ssl-min-ver TLSv1.2 no-tls-tickets
stats socket /var/lib/haproxy/stats uid 0 gid 0 mode 0640 level admin expose-fd listeners
stats socket /var/lib/haproxy/monitoring user root group monitoring mode 0660 level user
stats bind-process all
tune.bufsize 16384
tune.h2.max-concurrent-streams 8096
tune.maxrewrite 1024
tune.ssl.cachesize 100000
tune.ssl.lifetime 600
ulimit-n 500000
errorfile 400 /etc/haproxy/errors/400.html
errorfile 401 /etc/haproxy/errors/401.html
errorfile 403 /etc/haproxy/errors/403.html
errorfile 405 /etc/haproxy/errors/405.html
errorfile 408 /etc/haproxy/errors/408.html
errorfile 429 /etc/haproxy/errors/429.html
errorfile 500 /etc/haproxy/errors/500.html
errorfile 502 /etc/haproxy/errors/502.html
errorfile 503 /etc/haproxy/errors/503.html
errorfile 504 /etc/haproxy/errors/504.html
log-format "{ \"haproxy_log_format\":\"http\", \"haproxy_client_ip\":\"%ci\", \"haproxy_x_forwarded_for\":%{+Q}[capture.req.hdr(2)], \"haproxy_client_port\":\"%cp\", \"haproxy_date_time\":\"%t\", \"haproxy_frontend_name_transport\":\"%ft\", \"haproxy_backend_name\":\"%b\", \"haproxy_server_name\":\"%s\", \"haproxy_total_time\":%TR, \"haproxy_time_establish_tcp\":%Tc, \"haproxy_total_session_duration_time\":%Tt, \"haproxy_connection_handshake_time\":%Th, \"haproxy_bytes_read\":%B, \"haproxy_bytes_uploaded\":%U, \"haproxy_termination_state\":\"%ts\", \"haproxy_process_concurrent_connections\":%ac, \"haproxy_frontend_current_connections\":%fc, \"haproxy_backend_current_connections\":%bc, \"haproxy_server_concurrent_connections\":%sc, \"haproxy_retries\":%rc, \"haproxy_server_queue\":%sq, \"haproxy_backend_source_ip\":\"%bi\", \"haproxy_backend_source_port\":\"%bp\", \"haproxy_backend_queue\":%bq, \"haproxy_req_hrd_host\":%{+Q}[capture.req.hdr(0)], \"haproxy_req_hrd_user_agent\":%{+Q}[capture.req.hdr(1)], \"haproxy_ssl_ciphers\":\"%sslc\", \"haproxy_ssl_version\":\"%sslv\", \"haproxy_http_method\":\"%HM\", \"haproxy_http_ver\":\"%HV\", \"haproxy_request_url\":\"%HU\", \"haproxy_status_code\":%ST }"
maxconn 120000
timeout http-request 302s
timeout queue 60s
timeout client 302s
timeout server 302s
timeout check 1s
haproxy -vv
HAProxy version 2.6.15-1.el7 2023/08/09 - https://haproxy.org/
Status: long-term supported branch - will stop receiving fixes around Q2 2027.
Known bugs: http://www.haproxy.org/bugs/bugs-2.6.15.html
Running on: Linux 3.10.0-1160.99.1.el7.x86_64 #1 SMP Wed Sep 13 14:19:20 UTC 2023 x86_64
TARGET = linux-glibc
CC = cc
CFLAGS = -O2 -g -Wall -Wextra -Wundef -Wdeclaration-after-statement -Wfatal-errors -Wtype-limits -fwrapv -Wno-address-of-packed-member -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-clobbered -Wno-missing-field-initializers -Wno-cast-function-type -Wno-string-plus-int -Wno-atomic-alignment
OPTIONS = USE_PCRE=1 USE_OPENSSL=1 USE_LUA=1 USE_ZLIB=1 USE_DL=1 USE_SYSTEMD=1
Feature list : -51DEGREES +ACCEPT4 +BACKTRACE -CLOSEFROM +CPU_AFFINITY +CRYPT_H -DEVICEATLAS +DL -ENGINE +EPOLL -EVPORTS +GETADDRINFO -KQUEUE +LIBCRYPT +LINUX_SPLICE +LINUX_TPROXY +LUA -MEMORY_PROFILING +NETFILTER +NS -OBSOLETE_LINKER +OPENSSL -OT +PCRE -PCRE2 -PCRE2_JIT -PCRE_JIT +POLL +PRCTL -PROCCTL -PROMEX -QUIC +RT -SLZ -STATIC_PCRE -STATIC_PCRE2 +SYSTEMD +TFO +THREAD +THREAD_DUMP +TPROXY -WURFL +ZLIB
Built with multi-threading support (MAX_THREADS=64, default=3).
Built with Lua version : Lua 5.4.6
Built with gcc compiler version 4.8.5 20150623 (Red Hat 4.8.5-44)
Available services : none
[FCGI] fcgi-app
