I’ve setup a haproxy active-passive cluster using ucarp.
Now my question is: how would I synchronize backend state?
I.e. when I set the backend state to “drain” on one of the nodes I would like to have this change replicated to the other node.
This is a pity…
So either I need to remember to always perform changes on both systems. Or I do not use the web frontend at all but write some scripts to talk to both haproxy sockets or I give this a try: GitHub - chrislusf/teeproxy
