Hi
I would like to add some header to response if the path begins with something,
here is my config:
debug
frontend www
bind *:8000
http-response set-header TEST1 YES1 if { capture.req.uri -m beg /test/ }
default_backend be
backend be
acl is_test capture.req.uri -m beg /test/
http-response set-header TEST2 YES2 if is_test
server s1 127.0.0.1:8080
But it does not work. Please help
I’m using v1.9.2.
