HTTP/2: huge transfer-speed degradation
Most of HTTPS requests with HTTP/2 are slower than normal.
And there are some requests that are slower in 3-10 times. An extra time appears on “read request” stage.
Example:
I’ve tested with GTMetrix (some pages have 3-5 longer average full-load time), DareBoost and local test with Hey
For local test I’ve used single 14MB file and 10 threads.
  • Average request-time degradation 20-30%
  • Slowest requests are 1.5-3 times worse
It is with default tune-h2 settings.
Changing to the maximum header-table-size and 512MB initial-window-size makes it a bit better, but it is still much worse than HTTP/1.1.
HA-Proxy version 1.8.3-a91f55-27 (USE_GETADDRINFO=1 USE_ZLIB=1 USE_REGPARM=1 USE_OPENSSL=1 USE_LUA=1 USE_SYSTEMD=1 USE_PCRE=1 USE_PCRE_JIT=1 USE_TFO=1 USE_NS=1)
Does anyone see normal speed for HTTP/2?
tried testing with webpagetest.org in various web browsers ?
Dareboost and GTMetrix uses different browsers and Hey-script is one more way. So, it is 100% problem not from client.
Do you have any own HTTP2-tests? I want to know at least - is it Haproxy native problem, or something related to my settings or OS.
First versions of HTTP/2 support in some popular web-servers also were slower than normal, so it might be similar case for Haproxy
However, it is really huge difference
Okay did some Haproxy 1.8.3 tests and yes the HTTP/2 slowness compared to HTTP/1.1 might be related to images specifically. If you test non-image requests, HTTP/2 is faster while image requests HTTP/2 are slower.
haproxy -vv
HA-Proxy version 1.8.3-205f675 2017/12/30
Copyright 2000-2017 Willy Tarreau <willy@haproxy.org>
  TARGET  = linux2628
  CPU     = native
  CC      = gcc
  CFLAGS  = -march=native -m64 -march=x86-64 -O2 -g
  OPTIONS = USE_LINUX_SPLICE=1 USE_LINUX_TPROXY=1 USE_ZLIB=1 USE_REGPARM=1 USE_THREAD=1 USE_OPENSSL=1 USE_LUA=1 USE_PCRE=1 USE_PCRE_JIT=1
Built with OpenSSL version : OpenSSL 1.1.0g  2 Nov 2017
Running on OpenSSL version : OpenSSL 1.1.0g  2 Nov 2017
Built with PCRE version : 8.41 2017-07-05
Running on PCRE version : 8.41 2017-07-05
webpagetest filmstrips comparing
  • Centmin Mod Nginx 1.13.8 with proxy_cache and without proxy_cache
  • Haproxy 1.8.3 HTTP/2 HTTPS
  • Haproxy 1.8.3 HTTP/1.1 HTTPS
Visually Complete
Document Complete
Fully Loaded
nghttp2 h2load HTTP/1.1 and HTTP/2 HTTPS tests
  • port 447 = haproxy HTTP/1.1 HTTPS
  • port 444 = haproxy HTTP/2 HTTPS
for static index.html pages
/usr/local/bin/h2load -p http/1.1 -t2 -c50 -m100 -n10000 -H 'Accept-Encoding: gzip' https://baremetal.domain.com:447/
starting benchmark...
spawning thread #0: 25 total client(s). 5000 total requests
spawning thread #1: 25 total client(s). 5000 total requests
TLS Protocol: TLSv1.2
Cipher: ECDHE-RSA-AES128-GCM-SHA256
Server Temp Key: ECDH P-256 256 bits
Application protocol: http/1.1
progress: 10% done
progress: 20% done
progress: 30% done
progress: 40% done
progress: 50% done
progress: 60% done
progress: 70% done
progress: 80% done
progress: 90% done
progress: 100% done
finished in 357.96ms, 27935.93 req/s, 102.77MB/s
requests: 10000 total, 10000 started, 10000 done, 10000 succeeded, 0 failed, 0 errored, 0 timeout
status codes: 10000 2xx, 0 3xx, 0 4xx, 0 5xx
traffic: 36.79MB (38573750) total, 4.63MB (4853750) headers (space savings 0.00%), 31.33MB (32850000) data
                     min         max         mean         sd        +/- sd
time for request:      518us    214.16ms    122.48ms     54.81ms    68.33%
time for connect:    11.35ms     21.57ms     16.64ms      2.87ms    58.00%
time to 1st byte:    14.56ms     29.50ms     18.67ms      3.24ms    72.00%
req/s           :     559.41      655.22      592.42       24.24    76.00%
/usr/local/bin/h2load -t2 -c50 -m100 -n10000 -H 'Accept-Encoding: gzip' https://baremetal.domain.com:444/
Application protocol: h2
progress: 10% done
progress: 20% done
progress: 30% done
progress: 40% done
progress: 50% done
progress: 60% done
progress: 70% done
progress: 80% done
progress: 90% done
progress: 100% done
finished in 220.87ms, 45276.53 req/s, 92.80MB/s
traffic: 20.50MB (21490962) total, 4.09MB (4283750) headers (space savings 8.93%), 16.15MB (16930000) data
time for request:    11.02ms    165.97ms     68.03ms     25.02ms    71.41%
time for connect:    10.10ms     28.82ms     20.56ms      4.77ms    68.00%
time to 1st byte:    23.29ms    111.87ms     67.16ms     24.58ms    62.00%
req/s           :     909.67     1653.41     1122.10      181.65    74.00%
for png image
/usr/local/bin/h2load -p http/1.1 -t2 -c50 -m100 -n10000 -H 'Accept-Encoding: gzip' https://baremetal.domain.com:447/images/slide2.png
progress: 10% done
progress: 20% done
progress: 30% done
progress: 40% done
progress: 50% done
progress: 60% done
progress: 70% done
progress: 80% done
progress: 90% done
progress: 100% done
finished in 2.27s, 4397.64 req/s, 1.04GB/s
traffic: 2.36GB (2534863750) total, 4.24MB (4443750) headers (space savings 0.00%), 2.36GB (2529710000) data
time for request:     2.18ms       2.10s    804.63ms    380.48ms    75.73%
time for connect:     5.58ms     22.30ms     15.11ms      3.93ms    70.00%
time to 1st byte:    14.57ms     28.97ms     20.40ms      4.10ms    50.00%
req/s           :      87.98      104.10       96.25        3.88    76.00%
/usr/local/bin/h2load -t2 -c50 -m100 -n10000 -H 'Accept-Encoding: gzip' https://baremetal.domain.com:444/images/slide2.png
progress: 10% done
progress: 20% done
progress: 30% done
progress: 40% done
progress: 50% done
progress: 60% done
progress: 70% done
progress: 80% done
progress: 90% done
progress: 100% done
finished in 3.08s, 3244.12 req/s, 784.88MB/s
traffic: 2.36GB (2536928095) total, 3.66MB (3833750) headers (space savings 16.00%), 2.36GB (2529710000) data
time for request:    35.43ms       2.47s       1.11s    349.90ms    70.71%
time for connect:     5.42ms     29.75ms     16.00ms      6.16ms    72.00%
time to 1st byte:    23.08ms    199.11ms     89.85ms     34.39ms    68.00%
req/s           :      64.90      104.36       81.36        8.74    74.00%
For tests used my w3layout flatmate theme test site which you can find at GitHub - centminmod/testpages
Just noticed for Haproxy HTTP/2 h2load tests comparing png image vs static index.html, that header space savings for HPACK compression has a higher compression ratio for png image than static index.html at 16% saved vs 8.93% saved ? Why would png images compress more ?
Haproxy HTTP/1.1. HTTPS index.html
curl -I https://baremetal.domain.com:447/
HTTP/1.1 200 OK
Date: Fri, 09 Feb 2018 18:09:17 GMT
Content-Type: text/html; charset=utf-8
Content-Length: 4074
Last-Modified: Sun, 04 Feb 2018 12:30:13 GMT
Vary: Accept-Encoding
ETag: "5a76fcd5-fea"
Server: nginx centminmod
X-Powered-By: centminmod
Expires: Sun, 11 Mar 2018 18:09:17 GMT
Cache-Control: max-age=2592000
Access-Control-Allow-Origin: *
Cache-Control: public, must-revalidate, proxy-revalidate, immutable, stale-while-revalidate=86400, stale-if-error=604800
Accept-Ranges: bytes
Set-Cookie: SERVERID=1_server5; path=/
Haproxy HTTP/2. HTTPS index.html
curl -I https://baremetal.domain.com:444/
HTTP/2 200
date: Fri, 09 Feb 2018 18:09:21 GMT
content-type: text/html; charset=utf-8
content-length: 4074
last-modified: Sun, 04 Feb 2018 12:30:13 GMT
vary: Accept-Encoding
etag: "5a76fcd5-fea"
server: nginx centminmod
x-powered-by: centminmod
expires: Sun, 11 Mar 2018 18:09:21 GMT
cache-control: max-age=2592000
access-control-allow-origin: *
cache-control: public, must-revalidate, proxy-revalidate, immutable, stale-while-revalidate=86400, stale-if-error=604800
accept-language: bytes
set-cookie: SERVERID=1_server6; path=/
Haproxy HTTP/1.1. HTTPS png image
curl -I https://baremetal.domain.com:447/images/slide2.png
HTTP/1.1 200 OK
Date: Fri, 09 Feb 2018 19:10:42 GMT
Content-Type: image/png
Content-Length: 252971
Last-Modified: Fri, 09 Feb 2018 18:24:25 GMT
ETag: "5a7de759-3dc2b"
Expires: Sun, 11 Mar 2018 19:10:42 GMT
Set-Cookie: SERVERID=1_server10; path=/
Haproxy HTTP/2. HTTPS png image
curl -I https://baremetal.domain.com:444/images/slide2.png
HTTP/2 200
date: Fri, 09 Feb 2018 19:10:58 GMT
content-type: image/png
content-length: 252971
last-modified: Fri, 09 Feb 2018 18:24:25 GMT
etag: "5a7de759-3dc2b"
expires: Sun, 11 Mar 2018 19:10:58 GMT
set-cookie: SERVERID=1_server11; path=/
Thank you for such detailed tests
Only one thing to add. It is not about image and non-image. In your case for “index.html” - there is about 2 times less overall traffic (even for data-part). It should be the reason why H2 was so much faster.
I’ve seen degradation for html, js, css (gzipped and not), images and video.
Bigger file-size -> degradation is more significant and more often (many requests for small files are almost normal).
Now, I’ve retried tests with 1.8.4 and all the same.
This is may be unrelated, but compared to HTTP/1.1 H2 cannot reuse backend connections.
So to exclude this limitation as a possible factor in different performance figures, use “option http-server-close” instead of the default keep-alive mode, so H1 and H2 are comparable:
https://www.mail-archive.com/haproxy@formilux.org/msg28861.html
Unfortunately, that is really unrelated. It can make difference with a huge amount of requests and\or remote backends
This is 14mb video file from local backend:
HTTP/2
Total: 65.5290 secs
Slowest: 2.5039 secs
Fastest: 0.6438 secs
Average: 2.1648 secs
Requests/sec: 4.5781
Total data: 4333206300 bytes
Size/request: 14444021 bytes
HTTP/1.1
Total: 40.7544 secs
Slowest: 1.6909 secs
Fastest: 1.1414 secs
Average: 1.3568 secs
Requests/sec: 7.3612
ah yes that maybe the case
didn’t know that… unfortuately i have to spin down my server as vultr promo credits run out so will have to retest later on
Had hopes on last commit, but the problem still exists in 1.8.8
