Http request cannot pass thru when using load test tool
I am experience problem when using some load test tools such as Jmeter or Paessler Stress Tool.
The request could not able to pass thru the the haproxy. But it was success while manually access using typical browser. Please advise is it something need special in haproxy or load test tools?
haproxy code
log 127.0.0.1 local2
pidfile /var/run/haproxy.pid
maxconn 120
# turn on stats unix socket
timeout http-request 10s
timeout queue 30s
timeout client 1m
timeout server 1m
timeout http-keep-alive 10s
timeout check 10s
maxconn 110
frontend main
bind *:443
maxconn 105
default_backend app
backend app
fullconn 100
option ssl-hello-chk
option httpclose
server web1 10.0.0.6:443 check
bind *:1936
stats hide-version
stats uri /
stats auth xxxx:yyyy
stats refresh 10s
And the log from haproxy is
Jul 9 17:02:10 localhost haproxy[6949]: 220.241.111.222:64279 [09/Jul/2019:17:02:09.958] main app/web1 1/0/69 7 – 0/0/0/0/0 0/0
Jul 9 17:02:10 localhost haproxy[3857]: 220.241.111.222:15595 [09/Jul/2019:17:02:10.073] main app/web1 1/0/61 7 – 0/0/0/0/0 0/0
Jul 9 17:02:10 localhost haproxy[3910]: 220.241.111.222:1335 [09/Jul/2019:17:02:10.364] main app/web1 1/0/68 7 – 0/0/0/0/0 0/0
Jul 9 17:02:10 localhost haproxy[7163]: 220.241.111.222:3574 [09/Jul/2019:17:02:10.707] main main/ -1/-1/0 319 PR 1/0/0/0/0 0/0
Jul 9 17:02:10 localhost haproxy[3910]: 220.241.111.222:52196 [09/Jul/2019:17:02:10.686] main app/web1 1/1/58 7 – 0/0/0/0/0 0/0
Jul 9 17:02:10 localhost haproxy[2025]: 220.241.111.222:50675 [09/Jul/2019:17:02:10.755] main app/web1 1/1/51 7 – 0/0/0/0/0 0/0
Thanks!
I’m having the exact same issue using T-Rex traffic generator and posted a similar thread (HAProxy With Load Balancer) - am very interested if you figure this out.
Your server seems to be configured as an SSL server. It listen on the port 443 and you enable ssl checks (option ssl-hello-check). But the ssl is not enable on the server line.
SSL wasn’t terminated in the frontend either though; so there is a choice to make:
Either terminate SSL on both frontend and backend port 443, or in neither (in the latter case, the port 80 bind statement also has to go).
