Hello community!
I am trying to setup HAP as a Load Balancer to our backends which are running HAP as a reverse proxy (I try to use one tool instead of two, i.e. nginx). I am running HAP 2.8 in docker (default image, haproxy -vv below) on both servers. I know I could use mode tcp for tls forwarding on the load balancer but I need to use cookies for sticky sessions.
So far the setup is running and working, but my backend instance is getting spammed with the following error: loadbalancerIP:port all_frontend/2: SSL handshake failure.
I cannot find the root cause for it neither do I understand it. My guess is this is related to the health check because this is happening “in idle” without anyone trying to request the website.
I also noticed the backend only logs the IP from the load balancer for each site request. But this is another topic I guess.
server-full.pem file consists of (in this order): key, cert, ca2/intermediate, root
chain.pem file consists of: ca2/intermediate, root
Load Balancer
Summary
log stdout format raw local0
log stdout format raw local1 notice
stats socket /var/lib/haproxy/admin.sock user haproxy group haproxy mode 660 level admin expose-fd listeners
ssl-default-bind-ciphers ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:DHE-RSA-CHACHA20-POLY1305
ssl-default-bind-options prefer-client-ciphers no-sslv3 no-tlsv10 no-tlsv11 no-tls-tickets
ssl-default-server-ciphers ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:DHE-RSA-CHACHA20-POLY1305
ssl-dh-param-file /usr/local/etc/haproxy/dhparam2048.pem
option httpslog
timeout connect 120s
timeout client 120s
timeout server 120s
timeout http-request 120s
errorfile 400 /usr/local/etc/haproxy/errors/400.http
errorfile 403 /usr/local/etc/haproxy/errors/403.http
errorfile 408 /usr/local/etc/haproxy/errors/408.http
errorfile 500 /usr/local/etc/haproxy/errors/500.http
errorfile 502 /usr/local/etc/haproxy/errors/502.http
errorfile 503 /usr/local/etc/haproxy/errors/503.http
errorfile 504 /usr/local/etc/haproxy/errors/504.http
userlist AuthUsers
user admin password HASH
listen admin
bind *:8090 ssl crt /etc/ssl/certs/server-full.pem
stats uri /
stats refresh 5s
stats hide-version
http-request auth unless { http_auth(AuthUsers) }
frontend all_frontend
description Front-end for all traffic
bind *:443 ssl crt /etc/ssl/certs/server-full.pem
http-request set-header X-Real-IP %ci
http-request add-header X-Forwarded-Host %[req.hdr(host)]
http-response add-header X-XSS-Protection "1; mode=block"
http-response del-header X-Powered-By
http-response set-header Via "HTTP/2.0 loadbalancer.net"
redirect scheme https code 301 unless { ssl_fc }
default_backend jira_nodes
backend jira_nodes
server node1 node1.net:443 check ssl verify required ca-file /etc/ssl/certs/chain.pem cookie node1
server node2 node2.net:443 check ssl verify required ca-file /etc/ssl/certs/chain.pem cookie node2
Reverse Proxy
Summary
option httpslog
timeout client 120s
timeout server 120s
default-server init-addr last,libc,none
acl source_loadbalancer hdr(host) -i "loadbalancer.net"
acl source_directaccess hdr(host) -i "nodeX.net"
use_backend app_balanced if source_loadbalancer
use_backend app_directaccess if source_directaccess
server app_balanced host.docker.internal:8080 check
server app_directaccess host.docker.internal:8082 check
HAProxy Check
Summary
haproxy@fd1bf6560586:~$ haproxy -vv
HAProxy version 2.8.3-86e043a 2023/09/07 - https://haproxy.org/
Status: long-term supported branch - will stop receiving fixes around Q2 2028.
Known bugs: http://www.haproxy.org/bugs/bugs-2.8.3.html
Running on: Linux 5.4.0-144-generic #161-Ubuntu SMP Fri Feb 3 14:49:04 UTC 2023 x86_64
TARGET = linux-glibc
CC = cc
CFLAGS = -O2 -g -Wall -Wextra -Wundef -Wdeclaration-after-statement -Wfatal-errors -Wtype-limits -Wshift-negative-value -Wshift-overflow=2 -Wduplicated-cond -Wnull-dereference -fwrapv -Wno-address-of-packed-member -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-clobbered -Wno-missing-field-initializers -Wno-cast-function-type -Wno-string-plus-int -Wno-atomic-alignment
OPTIONS = USE_GETADDRINFO=1 USE_OPENSSL=1 USE_LUA=1 USE_PROMEX=1 USE_PCRE2=1 USE_PCRE2_JIT=1
Feature list : -51DEGREES +ACCEPT4 +BACKTRACE -CLOSEFROM +CPU_AFFINITY +CRYPT_H -DEVICEATLAS +DL -ENGINE +EPOLL -EVPORTS +GETADDRINFO -KQUEUE -LIBATOMIC +LIBCRYPT +LINUX_CAP +LINUX_SPLICE +LINUX_TPROXY +LUA +MATH -MEMORY_PROFILING +NETFILTER +NS -OBSOLETE_LINKER +OPENSSL -OPENSSL_WOLFSSL -OT -PCRE +PCRE2 +PCRE2_JIT -PCRE_JIT +POLL +PRCTL -PROCCTL +PROMEX -PTHREAD_EMULATION -QUIC +RT +SHM_OPEN +SLZ +SSL -STATIC_PCRE -STATIC_PCRE2 -SYSTEMD +TFO +THREAD +THREAD_DUMP +TPROXY -WURFL -ZLIB
Built with multi-threading support (MAX_TGROUPS=16, MAX_THREADS=256, default=2).
Built with OpenSSL version : OpenSSL 1.1.1n 15 Mar 2022
Running on OpenSSL version : OpenSSL 1.1.1n 15 Mar 2022
[BWLIM] bwlim-in
[BWLIM] bwlim-out
[FCGI] fcgi-app
Thanks for your time. I appreciate your help.
