Httpchk while in TCP mode not working, what's wrong?
frontend 443_oam
bind :443 # Frontend VIP IP and listener port
default_backend oam_443 # defines backend to use
backend oam_443 # Backend name referenced from frontend config
option httpchk get /check HTTP/1.0\r\nHost:\ http:///
default-server inter 3s fall 3 rise 2
option log-health-checks
server oam01 :443 check
This looks like it’s structured just like the examples that HAProxy give but when I start up HAProxy all I receive is
Message from syslogd@HAProxy2 at Dec 9 08:30:33 …
haproxy[4586]: backend oam_443 has no server available!
That’s not a valid HTTP request at all.
First of all you would UPPERCASE the “GET” and second of all “http:///” is not a valid host header.
If you don’t need the host header, just write:
option httpchk GET /check HTTP/1.0
Otherwise its:
option httpchk GET /check HTTP/1.0\r\nHost:\ www.example.com
edit: its port 443 so I assume this is encrypted SSL? You can’t HTTP request in cleartext if the server expects SSL either. Use sslchecks in that case.
I was able to solve the issue by doing:
frontend 443_oam
option httpchk GET http://www./index.html
server oam01 :443 check port 80
Ok, so you are checking port 80. httpchk syntax is still wrong though.
I solved as philipcowgill, version: 1.7.5.2
backend XXX
###CHECK
option httpchk GET /HAcheck.php  HTTP/1.0
http-check expect status 200
###END OF CHECK
server xxx 10.0.100.10:81 send-proxy check port 80 inter 2500 maxconn 2000
server yyy 10.0.100.11:81 send-proxy check port 80 inter 2500 maxconn 2000 backup
