HTTPS redirect on custom port not working
Hi there,
I have a setup with lot of services listening on custom ports.
The following configuration for a service listening on 45080 works fine if I enter https://my.web-site.com:45080
But gives ERR_EMPTY_RESPONSE if I type http://my.web-site.com:45080
Is this configuration possible to work when I have custom ports?
frontend web-site
    bind *:45080 ssl crt /etc/haproxy/certs/
    # logging options
    option log-separate-errors
    default_backend web-site.server
    server WEBSVR websvr check port 80
This is expected behavior. Port is configured for HTTPS / SSL.
Thank you Lukastribus
It now makes sense as I have configured the port for HTTPS/SSL.
