Good afternoon,
I have a HAProxy mounted on a Debian 10 (HA-Proxy version 2.0.7-1 ~ bpo10 + 1 2019/09/28) with Certbot 0.31.0 and wildcard certificate for my domain, what I need is one of the backend ( specifically it is a SMC Sophos with a self-signed certificate) ignore the self-signed certificate and can use the HAProxy to expose the service with the wildcard certificate, I have tried everything and there is no way to make it work, any ideas? please help!
frontend smc_Front
bind 10.15.0.30:443 ssl crt /etc/haproxy/certs/domain.com.pem
default_backend smc-backendbackend smc-backend
server smc 10.15.0.6:443 check ssl verify none
Thanks for your help!
Greetings!
