My app is running normally on IIS Windows. It’s a NextJS app set with basePath = /minisom. When I access the IIS 192… website, everything works normally. However, when I install HAProxy with these same settings, I keep getting 400, 503 errors until it updates and works (sometimes). Sometimes on the login page when I type my email and password, it shows my email and password in the URL. When the app works, a few minutes pass and it stops working again.
#ssl-default-bind-options no-sslv3
# Additional generic tuning
tune.ssl.cachesize 100000
maxconn 80000
nbproc 1
nbthread 2
cpu-map auto:1/1-2 0-1
maxconn 80000
timeout tunnel 12h
stats auth admin:n0ts03@5y
stats hide-version
stats show-node
stats refresh 10s
stats uri /haproxy?stats
# For HAProxy 2.0 and uCI 8.5
no option http-use-htx
Main entrypoint
frontend altitude_app_server_nossl
#use_backend catch_all_invalid unless { hdr(host) -i 192.168.0.164 || hdr(host) -i haproxy }
acl host_pro hdr(host) -i 192.168.0.164
acl url_uSupervisorWebApp path_beg -i /uSupervisorWebApp
acl url_XperienceRouting path_beg -i /XperienceRouting8
acl url_uAgentWeb path_beg -i /uAgentWeb /uAgentWeb8 /uAgentWeb8ASLRunner /WebRTCPhoneService/ws /WebRTCPhoneService /rabbitPublisher
acl url_SmasAlmada path_beg -i /smasalmada
acl url_devminison path_beg -i /minisom
# PRO
#use_backend pro_usupervisorwebapp_app_backend if host_pro url_uSupervisorWebApp
#use_backend pro_xperiencerouting_app_backend if host_pro url_XperienceRouting
#use_backend pro_swagger_app_backend if host_pro url_Swagger
use_backend pro_uagentwebrtc_app_backend if host_pro url_uAgentWeb
use_backend pro_smsalmada_app_backend if host_pro url_SmasAlmada
use_backend pro_devminison_app_backend if host_pro url_devminison
#option http-keep-alive
#option httpchk HEAD /minisom “HTTP/1.0\r\nHOST: agent.tejo.cc”
http-request set-header X-Real-IP %[src]
#http-request set-header X-ORIGIN-URL http://%[hdr(host)]%[path]
#server s1 127.0.0.1:1203 cookie s1 check addr 192.168.2.92 port 80
server s1 192.168.2.92:80 check
timeout server 20m
frontend n1_pro_frontend_dev
bind 127.0.0.1:1203
use_backend n1_pro_dev_srv if { path -i -m beg /minisom }
default_backend n1_pro_dev_srv
#reqrep ^([^\ :])\ /minisom/(.) \1\ /\2
http-request set-path /%[path]
