I have a syslog load-balancing configuration which works well. But have just noticed that the stats show no in/out bytes for the backend, which is incorrect.
Am I missing something in the following config? It’s pretty much taken from here.
# FrontEnd
log-forward syslog
bind 10.2.2.250:514
bind 10.2.2.250:1514
log backend@panoslog user
# BackEnd
backend panoslog
mode log
balance roundrobin # Balance algorithm
server syslog1 10.2.2.51:9001 log-proto octet-count check inter 1s fall 3 rise 6
server syslog2 10.2.2.52:9001 log-proto octet-count check inter 1s fall 3 rise 6
The stats UI reports one session to each backend server, but 0 bytes in and out. Another frontend (tcp) has ‘log global’ set and reports bytes for the frontend and the backend.
Just noticed this post, is there any news on implementing byte stats for log backends?
