I’ve been struggling trying to figure out why my iperf3 benchmark going through an HAProxy frontend keeps getting killed at the configured timeout value of 2 minutes even though it’s pushing over 2 gigabits/sec on each of 10 threads. If I raise the timeout values to beyond the iperf3 test duration, the benchmark runs with no issues. I guess I have 2 main questions. Why are the timeouts being applied by HAProxy even though the connections are clearly not idle? Why am I not capturing any TCP keepalive packets with tcpdump when I have the options in haproxy.cfg?
haproxy.cfg (3.1 version):
master-worker
pidfile /var/run/haproxy.pid
nbthread 4
maxconn 100000
hard-stop-after 30s
stats socket /var/lib/haproxy/stats mode 660 level admin expose-fd listeners
timeout client 120s
timeout server 120s
timeout tunnel 120s
frontend iperf3
bind 0.0.0.0:8500
option clitcpka
default_backend iperf3.8080
backend iperf3.8080
option srvtcpka
server iperf3 10.2.3.4:8080
sysctl keepalive settings (server, proxy, and client):
net.ipv4.tcp_keepalive_intvl = 5
net.ipv4.tcp_keepalive_probes = 5
net.ipv4.tcp_keepalive_time = 10
iperf3 server command line: iperf3 -s -p 8080
iperf3 client command line: iperf3 -c $HAPROXY_IP -p 8500 -P 10 -t 180
tcpdump command: tcpdump -i eth0 -n ‘tcp[tcpflags] & (tcp-ack) != 0 and tcp[tcpflags] & (tcp-syn|tcp-fin|tcp-rst) == 0 and tcp[32:4] = tcp[36:4] - 1’
I feel like there has to be something really basic that I’m overlooking here. Any insight is appreciated.
