Is HAProxy loadbalancing supported on Solaris 11 platform
As per the http://www.haproxy.org/#plat , I cannot see Solaris 11 platform in this list.
Is HAProxy supported on Solaris 11 platform?
I don’t see why it would not work on Solaris 11, however I’m not aware of anyone using recent haproxy code (1.8) on Solaris.
There is the possibility that compatibility fixes are needed when using Haproxy 1.8+.
when is the plan to support it on Solaris 11?
If there are issues with Solaris 11, we are gonna fix them. But someone has to report issues first.
If you need commercial guarantees, contact the folks at haproxy.com.
We want to use HAproxy for below server:
SunOS ieatrcxb6890 5.11 11.3 i86pc i386 i86pc
Could you please suggest which HAProxy jar we should download for Solaris 11 i886 hardware?
Regards,
Aditi
We do not provide binaries.
Compile from source or find a repository appropriate for this.
