We currently run Haproxy 1.7.10 on Debian 9.4 Stretch. We have used Haproxy for Load Balancing for about 4 to 5 years now without much of an issue. We recently read that starting in 1.8 band Haproxy can be multi threaded when ran vs single threaded, so we want to try to take advantage of this.
Unfortunately I am running into some errors when upgrading to 1.8. I do not get any configuration errors, so I believe our haproxy.cfg file is good, but I will post the rest of the errors I am getting below. I can go through the upgrade process like we have done many times, but at the end the Haproxy service fails to start.
Blockquote
root@lab-p02:/usr/src/haproxy-1.8.15# haproxy -vv
HA-Proxy version 1.8.15 2018/12/13
TARGET = linux2628
CC = gcc
CFLAGS = -O2 -g -fno-strict-aliasing -Wdeclaration-after-statement -fwrapv -Wno-null-dereference -Wno-unused-label
OPTIONS = USE_ZLIB=1 USE_OPENSSL=1 USE_PCRE=1
Built with OpenSSL version : OpenSSL 1.0.2q 20 Nov 2018
Running on OpenSSL version : OpenSSL 1.0.2q 20 Nov 2018
Blockquote
root@lab-p02:/usr/src/haproxy-1.8.15# service haproxy start
root@lab-p02:/usr/src/haproxy-1.8.15# service haproxy status
Loaded: loaded (/etc/systemd/system/haproxy.service; enabled; vendor preset: enabled)
Active: failed (Result: start-limit-hit) since Wed 2019-01-09 09:35:56 EST; 3s ago
Docs: man:haproxy(1)
Process: 23113 ExecStart=/usr/local/sbin/haproxy-systemd-wrapper -f ${CONFIG} -p /run/haproxy/haproxy.pid $EXTRAOPTS (code=exited, status=0/SUCCESS)
Process: 23111 ExecStartPre=/usr/local/sbin/haproxy -f ${CONFIG} -c -q (code=exited, status=0/SUCCESS)
Main PID: 23113 (code=exited, status=0/SUCCESS)
Jan 09 09:35:56 lab-p02 systemd[1]: haproxy.service: Service hold-off time over, scheduling restart.
Jan 09 09:35:56 lab-p02 systemd[1]: Stopped HAProxy Load Balancer.
Jan 09 09:35:56 lab-p02 systemd[1]: haproxy.service: Start request repeated too quickly.
Jan 09 09:35:56 lab-p02 systemd[1]: Failed to start HAProxy Load Balancer.
Jan 09 09:35:56 lab-p02 systemd[1]: haproxy.service: Unit entered failed state.
Jan 09 09:35:56 lab-p02 systemd[1]: haproxy.service: Failed with result ‘start-limit-hit’.
Blockquote
– The start-up result is done.
Jan 09 09:35:56 lab-p02 haproxy-systemd-wrapper[23113]: haproxy-systemd-wrapper: executing /usr/local/sbin/haproxy -f /etc/haproxy/haproxy.cfg -p /run/haproxy/haproxy.pid -Ds
Jan 09 09:35:56 lab-p02 haproxy-systemd-wrapper[23113]: haproxy-systemd-wrapper: exit, haproxy RC=0
Jan 09 09:35:56 lab-p02 systemd[1]: haproxy.service: Killing process 23116 (haproxy) with signal SIGKILL.
– Subject: Unit haproxy.service has finished shutting down
– Defined-By: systemd
– Support: Debian -- User Support
– Unit haproxy.service has finished shutting down.
– Subject: Unit haproxy.service has failed
– Unit haproxy.service has failed.
