Upgrade from 1.5 to 2.1 - Active: inactive (dead)
Running Centos 7
dev reshaproxy02.dev:root[/opt/haproxy-2.1.1]# cat /etc/redhat-release
CentOS Linux release 7.7.1908 (Core)
Upgraded HAPROXy from 1.5 to 2.1 and started having issue where the service wont start.
dev reshaproxy02.dev:root[/opt/haproxy-2.1.1]# systemctl status haproxy
Loaded: loaded (/usr/lib/systemd/system/haproxy.service; enabled; vendor preset: disabled)
Active: inactive (dead) since Tue 2019-12-17 13:38:04 MST; 58min ago
Process: 102700 ExecStart=/usr/sbin/haproxy-systemd-wrapper -f /etc/haproxy/haproxy.cfg -p /run/haproxy.pid $OPTIONS (code=exited, status=0/SUCCESS)
Main PID: 102700 (code=exited, status=0/SUCCESS)
Dec 17 13:38:04 reshaproxy02.dev.wdc1.wildblue.net systemd[1]: Started HAProxy Load Balancer.
Dec 17 13:38:04 reshaproxy02.dev.wdc1.wildblue.net haproxy-systemd-wrapper[102700]: haproxy-systemd-wrapper: executing /usr/sbin/haproxy -f /etc/haproxy/haproxy.cfg -p /run/haproxy.pid -Ds
Dec 17 13:38:04 reshaproxy02.dev.wdc1.wildblue.net haproxy-systemd-wrapper[102700]: haproxy-systemd-wrapper: exit, haproxy RC=0
My upgrade procedure
tar -zxvf haproxy-2.1.1.tar.gz
cd haproxy-2.1.1
yum install gcc pcre-static pcre-devel openssl-devel -y
make TARGET=linux-glibc USE_OPENSSL=1 USE_PCRE=1 USE_ZLIB=1
make install
cp /usr/local/sbin/haproxy /usr/bin
systemctl enable haproxy.service
systemctl start haproxy
Ive checked a few links from other upgrades that were posted on this site but none seem to help.
Anyone have any pointers that may help me get this fixed?
Thanks in advance.
You should uninstall haproxy 1.5 cleanly, so that when you do make a mistake while installing the new release, you get a proper error message instead of strange behavior.
When you did that, double check that there are no files like /usr/lib/systemd/system/haproxy.service, haproxy and especially /usr/sbin/haproxy-systemd-wrapper.
Please don’t do copy the executable around, what’s wrong with /usr/local/sbin/?
Once you have a clear situation, install the system unit file that ships with haproxy as per:
Once you have done all this, follow the procedure here to setup systemd:
This was in a book Im reading by Nick Ramirez, it was for HAProxy 1.5 to 1.6. I have since removed this and followed everything you have posted but now am getting a new error
Unit haproxy.service could not be found.
My procedure thus far…
Backup your config file to be safe.
Remove old 1.5.x haproxy
	yum remove haproxy
Verify your config file exists, may have been renamed when 1.5 was removed.
	ll /etc/haproxy/
	    haproxy.cfg.rpmsave
Rename it back to original.
    mv /etc/haproxy/haproxy.cfg.rpmsave /etc/haproxy/haproxy.cfg
Verify that "haproxy.service, haproxy" does not exist in /usr/lib/systemd/system/. If so, remove
	ll /usr/lib/systemd/system/ | grep haproxy
Verify "haproxy-systemd-wrapper" does not exit in /usr/sbin. If so, remove.
	ll /usr/sbin/ | grep haproxy
Verify haproxy is not using init.d. If so remove.
	ll /etc/init.d/ | grep haproxy
Download source to /opt
	cd /opt
	cd haproxy-2.1.1/
	yum install gcc pcre-static pcre-devel openssl-devel systemd-devel -y
	make TARGET=linux-glibc USE_OPENSSL=1 USE_PCRE=1 USE_ZLIB=1 USE_SYSTEMD=1
	make install
	cp /opt/haproxy-2.1.1/contrib/systemd/haproxy.service.in /lib/systemd/system/
	systemctl daemon-reload
Near the end for the copy statement of haproxy.service.in, should this be renamed to haproxy.service?
I don’t know all the CentOs specifics, maybe systemd doesn’t like that path in Centos.
Move the unit file to where the previous file was:
mv /lib/systemd/system/haproxy.service.in /usr/lib/systemd/system/haproxy.service
You posted before i could edit. That looks like it helped but still an error im googling for now. Appreciate the help.
   Loaded: error (Reason: Invalid argument)
Dec 18 07:23:58 reshaproxy02.dev.wdc1.wildblue.net systemd[1]: [/usr/lib/systemd/system/haproxy.service:9] Executable path is not absolute, ignoring: @SBINDIR@/haproxy -f $CONFIG -c -q $EXTRAOPTS
Dec 18 07:23:58 reshaproxy02.dev.wdc1.wildblue.net systemd[1]: [/usr/lib/systemd/system/haproxy.service:10] Executable path is not absolute, ignoring: @SBINDIR@/haproxy -Ws -f $CONFIG -p $PIDFILE $EXTRAOPTS
Dec 18 07:23:58 reshaproxy02.dev.wdc1.wildblue.net systemd[1]: [/usr/lib/systemd/system/haproxy.service:11] Executable path is not absolute, ignoring: @SBINDIR@/haproxy -f $CONFIG -c -q $EXTRAOPTS
Dec 18 07:23:58 reshaproxy02.dev.wdc1.wildblue.net systemd[1]: haproxy.service lacks both ExecStart= and ExecStop= setting. Refusing.
You can replace @SBINDIR@ with /usr/local/sbin/ manually, or remove the unit file and use the makefile in contrib/systemd.
Always systemctl daemon-reload after changes to the unit files.
Alright, and yet another issue. This one with less detail.
My config file is good
dev reshaproxy01.dev:root[~]# haproxy -c -f /etc/haproxy/haproxy.cfg
Configuration file is valid
dev reshaproxy01.dev:root[~]# journalctl -xe
> Dec 18 08:21:10 reshaproxy01.dev.wdc1.wildblue.net systemd[1]: haproxy.service: main process exited, code=exited, status=1/FAILURE
> Dec 18 08:21:10 reshaproxy01.dev.wdc1.wildblue.net systemd[1]: Failed to start HAProxy Load Balancer.
> – Subject: Unit haproxy.service has failed
> – Defined-By: systemd
> – Support: systemd-devel Info Page
> – Unit haproxy.service has failed.
> – The result is failed.
> Dec 18 08:21:10 reshaproxy01.dev.wdc1.wildblue.net systemd[1]: Unit haproxy.service entered failed state.
> Dec 18 08:21:10 reshaproxy01.dev.wdc1.wildblue.net systemd[1]: haproxy.service failed.
> Dec 18 08:21:10 reshaproxy01.dev.wdc1.wildblue.net systemd[1]: haproxy.service holdoff time over, scheduling restart.
> Dec 18 08:21:10 reshaproxy01.dev.wdc1.wildblue.net systemd[1]: Stopped HAProxy Load Balancer.
> – Subject: Unit haproxy.service has finished shutting down
> – Unit haproxy.service has finished shutting down.
> Dec 18 08:21:10 reshaproxy01.dev.wdc1.wildblue.net systemd[1]: start request repeated too quickly for haproxy.service
There is zero information in the journal about why it failed.
Can you provide the output of:
which haproxy
haproxy -vv
cat /usr/lib/systemd/system/haproxy.service
dev reshaproxy02.dev:root[~]# which haproxy
dev reshaproxy02.dev:root[~]# haproxy -vv
HA-Proxy version 2.1.1 2019/12/11 - https://haproxy.org/
Status: stable branch - will stop receiving fixes around Q1 2021.
Known bugs: http://www.haproxy.org/bugs/bugs-2.1.1.html
  TARGET  = linux-glibc
  CPU     = generic
  CC      = gcc
  CFLAGS  = -O2 -g -fno-strict-aliasing -Wdeclaration-after-statement -fwrapv -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-old-style-declaration -Wno-ignored-qualifiers -Wno-clobbered -Wno-missing-field-initializers -Wtype-limits
  OPTIONS = USE_PCRE=1 USE_OPENSSL=1 USE_ZLIB=1
Feature list : +EPOLL -KQUEUE -MY_EPOLL -MY_SPLICE +NETFILTER +PCRE -PCRE_JIT -PCRE2 -PCRE2_JIT +POLL -PRIVATE_CACHE +THREAD -PTHREAD_PSHARED -REGPARM -STATIC_PCRE -STATIC_PCRE2 +TPROXY +LINUX_TPROXY +LINUX_SPLICE +LIBCRYPT +CRYPT_H -VSYSCALL +GETADDRINFO +OPENSSL -LUA +FUTEX +ACCEPT4 -MY_ACCEPT4 +ZLIB -SLZ +CPU_AFFINITY +TFO +NS +DL +RT -DEVICEATLAS -51DEGREES -WURFL -SYSTEMD -OBSOLETE_LINKER +PRCTL +THREAD_DUMP -EVPORTS
Built with OpenSSL version : OpenSSL 1.0.2k-fips  26 Jan 2017
Running on OpenSSL version : OpenSSL 1.0.2k-fips  26 Jan 2017
              h2 : mode=HTTP       side=FE|BE     mux=H2
            fcgi : mode=HTTP       side=BE        mux=FCGI
       <default> : mode=HTTP       side=FE|BE     mux=H1
       <default> : mode=TCP        side=FE|BE     mux=PASS
Available services : none
	[FCGI] fcgi-app
dev reshaproxy02.dev:root[~]# systemctl status haproxy
   Active: failed (Result: start-limit) since Wed 2019-12-18 08:12:23 MST; 57min ago
 Main PID: 122435 (code=exited, status=1/FAILURE)
Dec 18 08:12:23 reshaproxy02.dev.wdc1.wildblue.net systemd[1]: haproxy.service: main process exited, code=exi...URE
Dec 18 08:12:23 reshaproxy02.dev.wdc1.wildblue.net systemd[1]: Failed to start HAProxy Load Balancer.
Dec 18 08:12:23 reshaproxy02.dev.wdc1.wildblue.net systemd[1]: Unit haproxy.service entered failed state.
Dec 18 08:12:23 reshaproxy02.dev.wdc1.wildblue.net systemd[1]: haproxy.service failed.
Dec 18 08:12:23 reshaproxy02.dev.wdc1.wildblue.net systemd[1]: haproxy.service holdoff time over, scheduling ...rt.
Dec 18 08:12:23 reshaproxy02.dev.wdc1.wildblue.net systemd[1]: Stopped HAProxy Load Balancer.
Dec 18 08:12:23 reshaproxy02.dev.wdc1.wildblue.net systemd[1]: start request repeated too quickly for haproxy...ice
Hint: Some lines were ellipsized, use -l to show in full.
dev reshaproxy02.dev:root[~]# cat /usr/lib/systemd/system/haproxy.service
[Unit]
After=network.target
[Service]
EnvironmentFile=-/etc/default/haproxy
EnvironmentFile=-/etc/sysconfig/haproxy
Environment="CONFIG=/etc/haproxy/haproxy.cfg" "PIDFILE=/run/haproxy.pid" "EXTRAOPTS=-S /run/haproxy-master.sock"
ExecStartPre=/usr/local/sbin/haproxy -f $CONFIG -c -q $EXTRAOPTS
ExecStart=/usr/local/sbin/haproxy -Ws -f $CONFIG -p $PIDFILE $EXTRAOPTS
ExecReload=/usr/local/sbin/haproxy -f $CONFIG -c -q $EXTRAOPTS
KillMode=mixed
Restart=always
SuccessExitStatus=143
Type=notify
# The following lines leverage SystemD's sandboxing options to provide
# defense in depth protection at the expense of restricting some flexibility
# in your setup (e.g. placement of your configuration files) or possibly
# reduced performance. See systemd.service(5) and systemd.exec(5) for further
# information.
# NoNewPrivileges=true
# ProtectHome=true
# If you want to use 'ProtectSystem=strict' you should whitelist the PIDFILE,
# any state files and any other files written using 'ReadWritePaths' or
# 'RuntimeDirectory'.
# ProtectSystem=true
# ProtectKernelTunables=true
# ProtectKernelModules=true
# ProtectControlGroups=true
# If your SystemD version supports them, you can add: @reboot, @swap, @sync
# SystemCallFilter=~@cpu-emulation @keyring @module @obsolete @raw-io
[Install]
WantedBy=multi-user.target
As always systemd completely hides the actual errors the application provides and makes it impossible to troubleshoot.
A shot in the dark: are you sure that no old haproxy instance is running? Please killall haproxy and retry.
Otherwise, you will have to start it manually and check if there are any errors:
/usr/local/sbin/haproxy -f /etc/haproxy/haproxy.cfg -db
Yeah, I dont see any process running for haproxy but oddly enough it has a main pid when running systemctl status haproxy. Maybe next option is to uninstall and try again? May have to remove the files manually as im not sure make uninstall will work. Thoughts? I also dont have to use haproxy 2.1 it was the most recent stable version is why I chose it. Wish there was an rpm for the install.
dev reshaproxy02.dev:root[/opt/haproxy-2.1.1]# ps -ef | grep haproxy
root      12468  11428  0 06:30 pts/0    00:00:00 grep --color=auto haproxy
   Active: failed (Result: start-limit) since Wed 2019-12-18 08:12:23 MST; 22h ago
Dec 18 08:12:23 reshaproxy02.dev.wdc1.wildblue.net systemd[1]: haproxy.service: main process exited, code=exited, status=1/FAILURE
Dec 18 08:12:23 reshaproxy02.dev.wdc1.wildblue.net systemd[1]: haproxy.service holdoff time over, scheduling restart.
Dec 18 08:12:23 reshaproxy02.dev.wdc1.wildblue.net systemd[1]: start request repeated too quickly for haproxy.service
You hinted to this before but not sure why this is the case. It seems as if some file was not being installed, even after a few attempts at the make install. HAproxy is now working. After I posted above I went and did a “make uninstall”
To fix the unknown issue this is what i did…
cd /opt/haproxy-2.1.1/
make uninstall
make install
cp /opt/haproxy-2.1.1/contrib/systemd/haproxy.service.in /lib/systemd/system/haproxy.service
vi /lib/systemd/system/haproxy.service #replace @SBINDIR@ with /usr/local/sbin/
And all is good now. Unbelievable. Again my only thought here is that there was a missing/corrupt/stale file for some reason.
Active: active (running) since Thu 2019-12-19 06:51:25 MST; 12min ago
Process: 14057 ExecStartPre=/usr/local/sbin/haproxy -f $CONFIG -c -q $EXTRAOPTS (code=exited, status=0/SUCCESS)
Main PID: 14060 (haproxy)
├─14060 /usr/local/sbin/haproxy -Ws -f /etc/haproxy/haproxy.cfg -p /run/haproxy.pid -S /run/haproxy-master.sock
└─14062 /usr/local/sbin/haproxy -Ws -f /etc/haproxy/haproxy.cfg -p /run/haproxy.pid -S /run/haproxy-master.sock
Dec 19 06:51:25 reshaproxy02.dev.wdc1.wildblue.net systemd[1]: Starting HAProxy Load Balancer...
Dec 19 06:51:25 reshaproxy02.dev.wdc1.wildblue.net haproxy[14060]: [NOTICE] 352/065125 (14060) : New worker #1 (14062) forked
Dec 19 06:51:25 reshaproxy02.dev.wdc1.wildblue.net systemd[1]: Started HAProxy Load Balancer.
@ lukastribus Thank you for the assistance.
