Greetings. I was keen on some specific functionality of haproxy so I built 1.7.0 on my CentOS 7 server. The build when fine and I didn’t really have any issues. However for the life of me I can not get it to be controlled with systemd. Here is what I have. This is the binary that I ended up with:
TARGET = linux2628
CC = gcc
CFLAGS = -O2 -g -fno-strict-aliasing -Wdeclaration-after-statement
OPTIONS = USE_ZLIB=1 USE_OPENSSL=1 USE_PCRE=1
Built without Lua support
and here is the startup issue that I get from systemd:
[root@haproxy haproxy-1.7.0]# systemctl -l status haproxy.service
● haproxy.service - SYSV: HA-Proxy is a TCP/HTTP reverse proxy which is particularly suited for high availability environments.
Loaded: loaded (/etc/rc.d/init.d/haproxy)
Active: failed (Result: exit-code) since Sat 2016-12-10 10:35:56 PST; 7min ago
Docs: man:systemd-sysv-generator(8)
Process: 19985 ExecStart=/etc/rc.d/init.d/haproxy start (code=exited, status=1/FAILURE)
Dec 10 10:35:56 haproxy.home.whootis.com systemd[1]: Starting SYSV: HA-Proxy is a TCP/HTTP reverse proxy which is particularly suited for high availability environments....
Dec 10 10:35:56 haproxy.home.whootis.com haproxy[19985]: /etc/rc.d/init.d/haproxy: line 26: [: =: unary operator expected
Dec 10 10:35:56 haproxy.home.whootis.com haproxy[19985]: /etc/rc.d/init.d/haproxy: line 98: /usr/sbin/haproxy: No such file or directory
Dec 10 10:35:56 haproxy.home.whootis.com haproxy[19985]: Errors found in configuration file, check it with 'haproxy check'.
Dec 10 10:35:56 haproxy.home.whootis.com systemd[1]: haproxy.service: control process exited, code=exited status=1
Dec 10 10:35:56 haproxy.home.whootis.com systemd[1]: Failed to start SYSV: HA-Proxy is a TCP/HTTP reverse proxy which is particularly suited for high availability environments..
Dec 10 10:35:56 haproxy.home.whootis.com systemd[1]: Unit haproxy.service entered failed state.
Dec 10 10:35:56 haproxy.home.whootis.com systemd[1]: haproxy.service failed.
The file in init.d doesn’t appear to be formatted incorrectly as far as I can tell, but here it is anyway:
[root@haproxy haproxy-1.7.0]# cat /etc/init.d/haproxy
#!/bin/sh
# chkconfig: - 85 15
# description: HA-Proxy is a TCP/HTTP reverse proxy which is particularly suited \
# for high availability environments.
# processname: haproxy
# config: /etc/haproxy/haproxy.cfg
# pidfile: /var/run/haproxy.pid
# Script Author: Simon Matter <simon.matter@invoca.ch>
# Version: 2004060600
# Source function library.
if [ -f /etc/init.d/functions ]; then
. /etc/init.d/functions
elif [ -f /etc/rc.d/init.d/functions ] ; then
. /etc/rc.d/init.d/functions
else
exit 0
fi
# Source networking configuration.
. /etc/sysconfig/network
# Check that networking is up.
[ ${NETWORKING} = "no" ] && exit 0
# This is our service name
BASENAME=`basename $0`
if [ -L $0 ]; then
BASENAME=`find $0 -name $BASENAME -printf %l`
BASENAME=`basename $BASENAME`
fi
BIN=/usr/sbin/$BASENAME
CFG=/etc/$BASENAME/$BASENAME.cfg
[ -f $CFG ] || exit 1
PIDFILE=/var/run/$BASENAME.pid
LOCKFILE=/var/lock/subsys/$BASENAME
RETVAL=0
start() {
quiet_check
if [ $? -ne 0 ]; then
echo "Errors found in configuration file, check it with '$BASENAME check'."
return 1
fi
echo -n "Starting $BASENAME: "
daemon $BIN -D -f $CFG -p $PIDFILE
RETVAL=$?
echo
[ $RETVAL -eq 0 ] && touch $LOCKFILE
return $RETVAL
stop() {
echo -n "Shutting down $BASENAME: "
killproc $BASENAME -USR1
RETVAL=$?
echo
[ $RETVAL -eq 0 ] && rm -f $LOCKFILE
[ $RETVAL -eq 0 ] && rm -f $PIDFILE
return $RETVAL
restart() {
quiet_check
return 1
fi
stop
start
reload() {
if ! [ -s $PIDFILE ]; then
return 0
fi
quiet_check
return 1
fi
$BIN -D -f $CFG -p $PIDFILE -sf $(cat $PIDFILE)
check() {
$BIN -c -q -V -f $CFG
quiet_check() {
$BIN -c -q -f $CFG
rhstatus() {
status $BASENAME
condrestart() {
[ -e $LOCKFILE ] && restart || :
# See how we were called.
case "$1" in
start)
start
stop)
stop
restart)
restart
reload)
reload
condrestart)
condrestart
status)
rhstatus
check)
check
echo $"Usage: $BASENAME {start|stop|restart|reload|condrestart|status|check}"
exit 1
esac
exit $?
