Hi, first of greetings to the beautiful people at HAProxy Forums. I am in dire need of help.
I have recently installed HAProxy 2.1.4 with LUA 5.3.5 on my CentOS server on linux 3.10.0-1062.el7.x86_64.
Here are my make arguments:
make USE_NS=1 USE_TFO=1 USE_OPENSSL=1 USE_ZLIB=1 USE_LUA=1 USE_PCRE=1 USE_SYSTEMD=1 USE_LIBCRYPT=1 USE_THREAD=1 TARGET=linux-glibc LUA_INC=/opt/lua-5.3.5/include LUA_LIB=/opt/lua-5.3.5/lib
Here is output from haproxy -vv:
[root@localhost haproxy-2.1.4]# haproxy -vv
HA-Proxy version 2.1.4 2020/04/02 - https://haproxy.org/
Status: stable branch - will stop receiving fixes around Q1 2021.
Known bugs: http://www.haproxy.org/bugs/bugs-2.1.4.html
TARGET = linux-glibc
CC = gcc
CFLAGS = -O2 -g -fno-strict-aliasing -Wdeclaration-after-statement -fwrapv -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-old-style-declaration -Wno-ignored-qualifiers -Wno-clobbered -Wno-missing-field-initializers -Wtype-limits
OPTIONS = USE_PCRE=1 USE_THREAD=1 USE_LIBCRYPT=1 USE_OPENSSL=1 USE_LUA=1 USE_ZLIB=1 USE_TFO=1 USE_NS=1 USE_SYSTEMD=1
Feature list : +EPOLL -KQUEUE -MY_EPOLL -MY_SPLICE +NETFILTER +PCRE -PCRE_JIT -PCRE2 -PCRE2_JIT +POLL -PRIVATE_CACHE +THREAD -PTHREAD_PSHARED -REGPARM -STATIC_PCRE -STATIC_PCRE2 +TPROXY +LINUX_TPROXY +LINUX_SPLICE +LIBCRYPT +CRYPT_H -VSYSCALL +GETADDRINFO +OPENSSL +LUA +FUTEX +ACCEPT4 -MY_ACCEPT4 +ZLIB -SLZ +CPU_AFFINITY +TFO +NS +DL +RT -DEVICEATLAS -51DEGREES -WURFL +SYSTEMD -OBSOLETE_LINKER +PRCTL +THREAD_DUMP -EVPORTS
<default> : mode=HTTP side=FE|BE mux=H1
<default> : mode=TCP side=FE|BE mux=PASS
Available services : none
[FCGI] fcgi-app
Then what I have done is the following:
mkdir -p /etc/haproxy
mkdir -p /var/lib/haproxy
touch /var/lib/haproxy/stats
ln -s /usr/local/sbin/haproxy /usr/sbin/haproxy
cp examples/haproxy.init /etc/init.d/haproxy
chmod 755 /etc/init.d/haproxy
systemctl daemon-reload
chkconfig haproxy on
useradd -r haproxy
When i start and stop via systemctl however, everything just works fine except for in the logs i get this: /etc/rc.d/init.d/haproxy: line 26: [: =: unary operator expected
Here is the full output:
**[root@localhost haproxy-2.1.4]# systemctl status haproxy
● haproxy.service - SYSV: HA-Proxy is a TCP/HTTP reverse proxy which is particularly suited for high availability environments.
Loaded: loaded (/etc/rc.d/init.d/haproxy; bad; vendor preset: disabled)
Active: active (running) since Fri 2020-04-24 16:32:51 IST; 9min ago
Docs: man:systemd-sysv-generator(8)
Process: 2028 ExecStop=/etc/rc.d/init.d/haproxy stop (code=exited, status=0/SUCCESS)
Process: 2048 ExecStart=/etc/rc.d/init.d/haproxy start (code=exited, status=0/SUCCESS)
Main PID: 2057 (haproxy)
└─2057 /usr/sbin/haproxy -D -f /etc/haproxy/haproxy.cfg -p /var/run/haproxy.pid
Apr 24 16:32:51 localhost.localdomain systemd[1]: Starting SYSV: HA-Proxy is a TCP/HTTP reverse proxy which is particularly suited for hi...nts....
Apr 24 16:32:51 localhost.localdomain haproxy[2048]: /etc/rc.d/init.d/haproxy: line 26: [: =: unary operator expected
Apr 24 16:32:51 localhost.localdomain haproxy[2048]: Starting haproxy: [ OK ]
Apr 24 16:32:51 localhost.localdomain systemd[1]: Started SYSV: HA-Proxy is a TCP/HTTP reverse proxy which is particularly suited for hig...ments..**
Now i can’t bang my head around as to why this line is there? Also, since it is evident that I compiled wth systemd I am aware that I have not copied the systemd service file. So when the do the following:
rm /etc/init.d/haproxy
cd contrib/systemd
cp haproxy.service.in /lib/systemd/system/
systemctl enable haproxy
systemctl start haproxy
I land in complete soup as now systemctl restart haproxy results the below:
[root@localhost haproxy-2.1.4]# systemctl start haproxy
Failed to start haproxy.service: Unit not found.
Unit haproxy.service could not be found.
So it seems like there is a file name mismatch so i manually rename the file and then now the results are as follows:
[root@localhost haproxy-2.1.4]# mv -v /lib/systemd/system/haproxy.service.in /lib/systemd/system/haproxy.service
‘/lib/systemd/system/haproxy.service.in’ -> ‘/lib/systemd/system/haproxy.service’
[root@localhost haproxy-2.1.4]# systemctl daemon-reload
[root@localhost haproxy-2.1.4]# systemctl restart haproxy
Failed to restart haproxy.service: Unit is not loaded properly: Invalid argument.
See system logs and 'systemctl status haproxy.service' for details.
[root@localhost haproxy-2.1.4]# systemctl status haproxy.service
Loaded: error (Reason: Invalid argument)
Active: inactive (dead) since Fri 2020-04-24 16:48:03 IST; 3min 53s ago
Main PID: 2057 (code=killed, signal=TERM)
Apr 24 16:48:03 localhost.localdomain systemd[1]: Stopping haproxy.service...
Apr 24 16:48:03 localhost.localdomain systemd[1]: Stopped haproxy.service.
Apr 24 16:51:40 localhost.localdomain systemd[1]: [/usr/lib/systemd/system/haproxy.service:9] Executable path is not absolute, ignoring: ...TRAOPTS
Apr 24 16:51:40 localhost.localdomain systemd[1]: [/usr/lib/systemd/system/haproxy.service:10] Executable path is not absolute, ignoring:...TRAOPTS
Apr 24 16:51:40 localhost.localdomain systemd[1]: [/usr/lib/systemd/system/haproxy.service:11] Executable path is not absolute, ignoring:...TRAOPTS
Apr 24 16:51:40 localhost.localdomain systemd[1]: haproxy.service lacks both ExecStart= and ExecStop= setting. Refusing.
Hint: Some lines were ellipsized, use -l to show in full.
I am looking for some urgent help here. Thanks in advance.
Regards,
