Issues with HAProxy 2.0.25 Upgrade and OpenSSL 3.0
I am trying to upgrade from HAProxy 1.5 to 2.0 and I ran into some SSL issues during installation. I updated my make command to the following which decreased the total errors by 80% but I am still getting SSL.sock errors. Any help would be greatly appreciated.
Dist: CentOS 7
OpenSSL Data
openssl version -a
OpenSSL 3.0.0 7 sep 2021 (Library: OpenSSL 3.0.0 7 sep 2021)
built on: Thu Oct 14 17:07:54 2021 UTC
platform: linux-x86_64
options: bn(64,64)
compiler: gcc -fPIC -pthread -m64 -Wa,–noexecstack -Wall -O3 -DOPENSSL_USE_NODELETE -DL_ENDIAN -DOPENSSL_PIC -DOPENSSL_BUILDING_OPENSSL -DZLIB -DNDEBUG
OPENSSLDIR: “/usr/local/ssl”
ENGINESDIR: “/usr/local/ssl/lib64/engines-3”
MODULESDIR: “/usr/local/ssl/lib64/ossl-modules”
Seeding source: os-specific
CPUINFO: OPENSSL_ia32cap=0x80202001478bfffd:0x0
HAProxy Version
haproxy -v
HA-Proxy version 2.0.25-6986403 2021/09/07 - https://haproxy.org/
ERROR
make TARGET=linux-glibc USE_PCRE=1 USE_OPENSSL=1 SSL_INC=/usr/local/ssl/include/openssl SSL_LIB=/usr/local/ssl/lib64 USE_ZLIB=1 USE_CRYPT_H=1 USE_LIBCRYPT=1
LD haproxy
src/ssl_sock.o: In function ssl_sock_ocsp_stapling_cbk': /usr/src/haproxy-2.0.25/src/ssl_sock.c:1141: undefined reference to EVP_PKEY_base_id’
src/ssl_sock.o: In function ssl_get_tmp_dh': /usr/src/haproxy-2.0.25/src/ssl_sock.c:2689: undefined reference to EVP_PKEY_base_id’
/usr/src/haproxy-2.0.25/src/ssl_sock.c:2695: undefined reference to EVP_PKEY_bits' src/ssl_sock.o: In function smp_fetch_ssl_c_used’:
/usr/src/haproxy-2.0.25/src/ssl_sock.c:7108: undefined reference to SSL_get_peer_certificate' src/ssl_sock.o: In function smp_fetch_ssl_x_sig_alg’:
/usr/src/haproxy-2.0.25/src/ssl_sock.c:7181: undefined reference to SSL_get_peer_certificate' src/ssl_sock.o: In function smp_fetch_ssl_x_serial’:
/usr/src/haproxy-2.0.25/src/ssl_sock.c:6813: undefined reference to SSL_get_peer_certificate' src/ssl_sock.o: In function smp_fetch_ssl_x_s_dn’:
/usr/src/haproxy-2.0.25/src/ssl_sock.c:7056: undefined reference to SSL_get_peer_certificate' src/ssl_sock.o: In function smp_fetch_ssl_x_version’:
/usr/src/haproxy-2.0.25/src/ssl_sock.c:7141: undefined reference to SSL_get_peer_certificate' src/ssl_sock.o:/usr/src/haproxy-2.0.25/src/ssl_sock.c:6861: more undefined references to SSL_get_peer_certificate’ follow
src/ssl_sock.o: In function ssl_sock_do_create_cert': /usr/src/haproxy-2.0.25/src/ssl_sock.c:1924: undefined reference to EVP_PKEY_base_id’
src/ssl_sock.o: In function ssl_sock_load_ocsp': /usr/src/haproxy-2.0.25/src/ssl_sock.c:1327: undefined reference to EVP_PKEY_base_id’
/usr/src/haproxy-2.0.25/src/ssl_sock.c:1293: undefined reference to EVP_PKEY_base_id' src/ssl_sock.o: In function ssl_sock_load_cert_chain_file’:
/usr/src/haproxy-2.0.25/src/ssl_sock.c:3446: undefined reference to EVP_PKEY_bits' /usr/src/haproxy-2.0.25/src/ssl_sock.c:3447: undefined reference to EVP_PKEY_base_id’
src/ssl_sock.o: In function ssl_sock_get_pkey_algo': /usr/src/haproxy-2.0.25/src/ssl_sock.c:6251: undefined reference to EVP_PKEY_bits’
/usr/src/haproxy-2.0.25/src/ssl_sock.c:6252: undefined reference to EVP_PKEY_base_id' src/ssl_sock.o: In function ssl_sock_get_remote_common_name’:
/usr/src/haproxy-2.0.25/src/ssl_sock.c:6603: undefined reference to SSL_get_peer_certificate' src/ssl_sock.o: In function ssl_sock_get_cert_used_sess’:
/usr/src/haproxy-2.0.25/src/ssl_sock.c:6630: undefined reference to `SSL_get_peer_certificate’
collect2: error: ld returned 1 exit status
make: *** [haproxy] Error 1
Haproxy is not yet compatible with the API changes in OpenSSL 3.0.
Thanks for response. Is HAProxy 2.4.7 compatible with OpenSSL 1.1.1l?
Yes, absolutely!
I tried to compile with OpenSSL 1.1.1l and got the following error.
OpenSSL Version
openssl version -a
OpenSSL 1.1.1l 24 Aug 2021
built on: Fri Oct 15 16:50:01 2021 UTC
options: bn(64,64) rc4(16x,int) des(int) idea(int) blowfish(ptr)
compiler: gcc -fPIC -pthread -m64 -Wa,–noexecstack -Wall -O3 -DOPENSSL_USE_NODELETE -DL_ENDIAN -DOPENSSL_PIC -DOPENSSL_CPUID_OBJ -DOPENSSL_IA32_SSE2 -DOPENSSL_BN_ASM_MONT -DOPENSSL_BN_ASM_MONT5 -DOPENSSL_BN_ASM_GF2m -DSHA1_ASM -DSHA256_ASM -DSHA512_ASM -DKECCAK1600_ASM -DRC4_ASM -DMD5_ASM -DAESNI_ASM -DVPAES_ASM -DGHASH_ASM -DECP_NISTZ256_ASM -DX25519_ASM -DPOLY1305_ASM -DZLIB -DNDEBUG
OPENSSLDIR: “/usr/local/openssl”
ENGINESDIR: “/usr/local/openssl/lib/engines-1.1”
Error
make TARGET=linux-glibc USE_NS=1 USE_TFO=1 USE_PCRE=1 USE_ZLIB=1 USE_CRYPT_H=1 USE_LIBCRYPT=1 USE_OPENSSL=1 SSL_INC=/usr/local/openssl/include/openssl SSL_LIB=/usr/local/openssl/lib
CC src/ssl_sock.o
src/ssl_sock.c: In function ‘ssl_sock_dump_errors’:
src/ssl_sock.c:656:12: warning: ‘ERR_func_error_string’ is deprecated (declared at /usr/local/include/openssl/err.h:447): Since OpenSSL 3.0 [-Wdeprecated-declarations]
ERR_func_error_string(ret), ERR_reason_error_string(ret));
src/ssl_sock.c: In function ‘ssl_init_single_engine’:
src/ssl_sock.c:670:2: warning: ‘ENGINE_by_id’ is deprecated (declared at /usr/local/include/openssl/engine.h:336): Since OpenSSL 3.0 [-Wdeprecated-declarations]
engine = ENGINE_by_id(engine_id);
src/ssl_sock.c:676:2: warning: ‘ENGINE_init’ is deprecated (declared at /usr/local/include/openssl/engine.h:620): Since OpenSSL 3.0 [-Wdeprecated-declarations]
if (!ENGINE_init(engine)) {
src/ssl_sock.c:682:2: warning: ‘ENGINE_set_default_string’ is deprecated (declared at /usr/local/include/openssl/engine.h:685): Since OpenSSL 3.0 [-Wdeprecated-declarations]
if (ENGINE_set_default_string(engine, def_algorithms) == 0) {
src/ssl_sock.c:700:2: warning: ‘ENGINE_finish’ is deprecated (declared at /usr/local/include/openssl/engine.h:628): Since OpenSSL 3.0 [-Wdeprecated-declarations]
ENGINE_finish(engine);
src/ssl_sock.c:704:2: warning: ‘ENGINE_free’ is deprecated (declared at /usr/local/include/openssl/engine.h:493): Since OpenSSL 3.0 [-Wdeprecated-declarations]
ENGINE_free(engine);
src/ssl_sock.c: In function ‘ssl_tlsext_ticket_key_cb’:
src/ssl_sock.c:1107:4: warning: ‘HMAC_Init_ex’ is deprecated (declared at /usr/local/include/openssl/hmac.h:43): Since OpenSSL 3.0 [-Wdeprecated-declarations]
HMAC_Init_ex(hctx, keys[head].key_128.hmac_key, 16, TLS_TICKET_HASH_FUNCT(), NULL);
src/ssl_sock.c:1115:4: warning: ‘HMAC_Init_ex’ is deprecated (declared at /usr/local/include/openssl/hmac.h:43): Since OpenSSL 3.0 [-Wdeprecated-declarations]
HMAC_Init_ex(hctx, keys[head].key_256.hmac_key, 32, TLS_TICKET_HASH_FUNCT(), NULL);
src/ssl_sock.c:1128:4: warning: ‘HMAC_Init_ex’ is deprecated (declared at /usr/local/include/openssl/hmac.h:43): Since OpenSSL 3.0 [-Wdeprecated-declarations]
HMAC_Init_ex(hctx, keys[(head + i) % TLS_TICKETS_NO].key_128.hmac_key, 16, TLS_TICKET_HASH_FUNCT(), NULL);
src/ssl_sock.c:1135:4: warning: ‘HMAC_Init_ex’ is deprecated (declared at /usr/local/include/openssl/hmac.h:43): Since OpenSSL 3.0 [-Wdeprecated-declarations]
HMAC_Init_ex(hctx, keys[(head + i) % TLS_TICKETS_NO].key_256.hmac_key, 32, TLS_TICKET_HASH_FUNCT(), NULL);
src/ssl_sock.c: In function ‘ssl_sock_do_create_cert’:
src/ssl_sock.c:2059:2: warning: ‘SSL_CTX_set_tmp_dh_callback’ is deprecated (declared at /usr/local/include/openssl/ssl.h:2213): Since OpenSSL 3.0 [-Wdeprecated-declarations]
SSL_CTX_set_tmp_dh_callback(ssl_ctx, ssl_get_tmp_dh);
src/ssl_sock.c:2069:3: warning: ‘EC_KEY_new_by_curve_name’ is deprecated (declared at /usr/local/include/openssl/ec.h:996): Since OpenSSL 3.0 [-Wdeprecated-declarations]
if (!(ecc = EC_KEY_new_by_curve_name(nid)))
src/ssl_sock.c:2072:3: warning: ‘EC_KEY_free’ is deprecated (declared at /usr/local/include/openssl/ec.h:1001): Since OpenSSL 3.0 [-Wdeprecated-declarations]
EC_KEY_free(ecc);
In file included from include/haproxy/openssl-compat.h:7:0,
from include/haproxy/listener-t.h:37,
from include/haproxy/server-t.h:36,
from include/haproxy/lb_map-t.h:26,
from include/haproxy/backend-t.h:30,
from include/haproxy/proxy-t.h:35,
from include/haproxy/applet-t.h:31,
from include/haproxy/action-t.h:25,
from include/haproxy/stream.h:25,
from include/haproxy/channel.h:30,
from src/ssl_sock.c:51:
src/ssl_sock.c: In function ‘ctx_set_TLSv13_func’:
src/ssl_sock.c:2273:5: error: missing binary operator before token “1”
#if SSL_OP_NO_TLSv1_3
src/ssl_sock.c: In function ‘ssl_set_TLSv13_func’:
src/ssl_sock.c:2279:5: error: missing binary operator before token “1”
src/ssl_sock.c: In function ‘ssl_get_dh_1024’:
src/ssl_sock.c:2697:2: warning: ‘DH_new’ is deprecated (declared at /usr/local/include/openssl/dh.h:199): Since OpenSSL 3.0 [-Wdeprecated-declarations]
DH *dh = DH_new();
src/ssl_sock.c:2703:4: warning: ‘DH_free’ is deprecated (declared at /usr/local/include/openssl/dh.h:200): Since OpenSSL 3.0 [-Wdeprecated-declarations]
DH_free(dh);
src/ssl_sock.c:2706:4: warning: ‘DH_set0_pqg’ is deprecated (declared at /usr/local/include/openssl/dh.h:255): Since OpenSSL 3.0 [-Wdeprecated-declarations]
DH_set0_pqg(dh, p, NULL, g);
src/ssl_sock.c: In function ‘ssl_get_dh_2048’:
src/ssl_sock.c:2744:2: warning: ‘DH_new’ is deprecated (declared at /usr/local/include/openssl/dh.h:199): Since OpenSSL 3.0 [-Wdeprecated-declarations]
DH *dh = DH_new();
src/ssl_sock.c:2750:4: warning: ‘DH_free’ is deprecated (declared at /usr/local/include/openssl/dh.h:200): Since OpenSSL 3.0 [-Wdeprecated-declarations]
DH_free(dh);
src/ssl_sock.c:2753:4: warning: ‘DH_set0_pqg’ is deprecated (declared at /usr/local/include/openssl/dh.h:255): Since OpenSSL 3.0 [-Wdeprecated-declarations]
src/ssl_sock.c: In function ‘ssl_get_dh_4096’:
src/ssl_sock.c:2812:2: warning: ‘DH_new’ is deprecated (declared at /usr/local/include/openssl/dh.h:199): Since OpenSSL 3.0 [-Wdeprecated-declarations]
DH *dh = DH_new();
src/ssl_sock.c:2818:4: warning: ‘DH_free’ is deprecated (declared at /usr/local/include/openssl/dh.h:200): Since OpenSSL 3.0 [-Wdeprecated-declarations]
DH_free(dh);
src/ssl_sock.c:2821:4: warning: ‘DH_set0_pqg’ is deprecated (declared at /usr/local/include/openssl/dh.h:255): Since OpenSSL 3.0 [-Wdeprecated-declarations]
src/ssl_sock.c: In function ‘ssl_sock_get_dh_from_file’:
src/ssl_sock.c:2872:2: warning: ‘PEM_read_bio_DHparams’ is deprecated (declared at /usr/local/include/openssl/pem.h:469): Since OpenSSL 3.0 [-Wdeprecated-declarations]
dh = PEM_read_bio_DHparams(in, NULL, NULL, NULL);
src/ssl_sock.c: In function ‘ssl_sock_load_dh_params’:
src/ssl_sock.c:3093:4: warning: ‘SSL_CTX_set_tmp_dh_callback’ is deprecated (declared at /usr/local/include/openssl/ssl.h:2213): Since OpenSSL 3.0 [-Wdeprecated-declarations]
SSL_CTX_set_tmp_dh_callback(ctx, ssl_get_tmp_dh);
src/ssl_sock.c: In function ‘ssl_sock_prepare_ctx’:
src/ssl_sock.c:4490:3: warning: ‘EC_KEY_new_by_curve_name’ is deprecated (declared at /usr/local/include/openssl/ec.h:996): Since OpenSSL 3.0 [-Wdeprecated-declarations]
if (!i || ((ecdh = EC_KEY_new_by_curve_name(i)) == NULL)) {
src/ssl_sock.c:4497:4: warning: ‘EC_KEY_free’ is deprecated (declared at /usr/local/include/openssl/ec.h:1001): Since OpenSSL 3.0 [-Wdeprecated-declarations]
EC_KEY_free(ecdh);
src/ssl_sock.c: In function ‘__ssl_sock_init’:
src/ssl_sock.c:7129:2: warning: ‘ENGINE_load_builtin_engines’ is deprecated (declared at /usr/local/include/openssl/engine.h:358): Since OpenSSL 3.0 [-Wdeprecated-declarations]
ENGINE_load_builtin_engines();
src/ssl_sock.c:7149:2: warning: ‘ERR_load_SSL_strings’ is deprecated (declared at /usr/local/include/openssl/sslerr_legacy.h:29): Since OpenSSL 3.0 [-Wdeprecated-declarations]
ERR_load_SSL_strings();
src/ssl_sock.c: In function ‘ssl_free_engines’:
src/ssl_sock.c:7225:3: warning: ‘ENGINE_finish’ is deprecated (declared at /usr/local/include/openssl/engine.h:628): Since OpenSSL 3.0 [-Wdeprecated-declarations]
ENGINE_finish(wl->e);
src/ssl_sock.c:7226:3: warning: ‘ENGINE_free’ is deprecated (declared at /usr/local/include/openssl/engine.h:493): Since OpenSSL 3.0 [-Wdeprecated-declarations]
ENGINE_free(wl->e);
src/ssl_sock.c: In function ‘ssl_free_dh’:
src/ssl_sock.c:7236:3: warning: ‘DH_free’ is deprecated (declared at /usr/local/include/openssl/dh.h:200): Since OpenSSL 3.0 [-Wdeprecated-declarations]
DH_free(local_dh_1024);
src/ssl_sock.c:7240:3: warning: ‘DH_free’ is deprecated (declared at /usr/local/include/openssl/dh.h:200): Since OpenSSL 3.0 [-Wdeprecated-declarations]
DH_free(local_dh_2048);
src/ssl_sock.c:7244:3: warning: ‘DH_free’ is deprecated (declared at /usr/local/include/openssl/dh.h:200): Since OpenSSL 3.0 [-Wdeprecated-declarations]
DH_free(local_dh_4096);
src/ssl_sock.c:7248:3: warning: ‘DH_free’ is deprecated (declared at /usr/local/include/openssl/dh.h:200): Since OpenSSL 3.0 [-Wdeprecated-declarations]
DH_free(global_dh);
make: *** [src/ssl_sock.o] Error 1
Yes, because you are not compiling against OpenSSL 1.1.1.
The error message literally say 34 times that OpenSSL 3.0 is used (“Since OpenSSL 3.0 …”).
Thanks for responding, not trying to be lazy, I saw that but OpenSSL 3.0 was removed and I installed OpenSSL 1.1.1l and checked the version. So I guess this is saying that there is some remnants of 3.0 hanging out somewhere in the server? Sorry, not trying to be a n00b
Correct. Unfortunately I cannot directly help you with this, because it would require a lot of time and back and forth.
Appreciate that, I ran a find and found some left over libs/paths/files that have been removed. I ran the following and have a new set of errors not related to OpenSSL 3.0.
src/ssl_sample.o: In function smp_fetch_ssl_x_version': /usr/src/haproxy-2.4.7/src/ssl_sample.c:608: undefined reference to SSL_get1_peer_certificate’
src/ssl_sample.o: In function smp_fetch_ssl_c_used': /usr/src/haproxy-2.4.7/src/ssl_sample.c:569: undefined reference to SSL_get1_peer_certificate’
src/ssl_sample.o: In function smp_fetch_ssl_x_sha1': /usr/src/haproxy-2.4.7/src/ssl_sample.c:289: undefined reference to SSL_get1_peer_certificate’
src/ssl_sample.o: In function smp_fetch_ssl_x_serial': /usr/src/haproxy-2.4.7/src/ssl_sample.c:235: undefined reference to SSL_get1_peer_certificate’
src/ssl_sample.o: In function smp_fetch_ssl_x_s_dn': /usr/src/haproxy-2.4.7/src/ssl_sample.c:512: undefined reference to SSL_get1_peer_certificate’
src/ssl_sample.o:/usr/src/haproxy-2.4.7/src/ssl_sample.c:654: more undefined references to `SSL_get1_peer_certificate’ follow
This is gonna be a never ending back and forth for which I do not have the time.
Quick suggestion: install the OS from scratch and follow the advice in the INSTALL haproxy tarball:
http://git.haproxy.org/?p=haproxy-2.4.git;a=blob;f=INSTALL;h=85e8e8f59b3c5032d15231577f71a5b47330e4ec;hb=HEAD#l225
Mainly:
  • don’t install openssl in standard paths or even /usr/local/
  • build it statically, not dynamically, otherwise things get even more complex
