LB complex algorithms combination and anonymity issues
Detailed Description of the Problem
Shot out to the HaProxy team and maintainers, keep up the good work guys !
I am in the situation of managing a complex proxy architecture composed of multiple chained load balancers each of them implementing diffent load balancing algorithms and routing request in the final stage to a specific pool of proxies.
I am encoutering 3 different issues which neither the official nor unofficial documentations are adressing completely.
1. I want to route my requests according to its final destination regarding both the dns of the endpoint targeted or/and some part of the url path. I have not found satisfying results using the following config :
I have tried path_beg, path_end, path_sub with the following config :
        bind *:8080
        acl admin_url path_sub admin
        use_backend srvs_app1 if admin_url
backend srvs_app1
        server host1 HOST1_IP:PORT1 check
        server host2 HOST2_IP:PORT2 check
2 I use to spoof some requests parameters using a Squid and an Elite configuration according to this article https://www.metahackers.pro/setup-high-anonymous-elite-proxy/. Although, I wish not to use Elite Squid nodes as a spoofing layer in my infrastructure anymore, hence I was curious to know if such an Anonymous/Elite configuration exists on HaProxy. Any help on this point would be appriciated.
3 Some of my load balancers have to implement a Least Time type algorithms and some other need to use a combination of a Power of two random choices type algorithm with a Least Time one after the random selection of two nodes have been done. I have found 2 relevant articles refering to such a set up, one for HaProxy (Test driving “power of two random choices” load balancing) and one for NGINX (https://www.nginx.com/blog/nginx-power-of-two-choices-load-balancing-algorithm/).
In HaProxy official documentation, I have yet not found any reference to a Least Time or any combination of Power of two random choices and Least Time algorithms : DevDocs
This 3rd point critical, I really wish you guys will provide me with a clear answer on this one !
Cheers
Expected Behavior
1 Being able to route my requests to different nodes according to the request endpoint url informations (DNS, Path) with path_sub and a combination of conditions (peferably with Regular Expressions).
2 Provide my HaProxy configurations with Elite/Anonymous settings.
3 Implement Least Time algorithms alone but as well combined with Power of two random choices type algorithms ( Random Two and Least Time on the random choice resulting nodes)
The infra should look as so :
Output of haproxy -vv
HA-Proxy version 2.0.13-2ubuntu0.5 2022/03/02 - https://haproxy.org/
  TARGET  = linux-glibc
  CPU     = generic
  CC      = gcc
  CFLAGS  = -O2 -g -O2 -fdebug-prefix-map=/build/haproxy-qHmAxE/haproxy-2.0.13=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fno-strict-aliasing -Wdeclaration-after-statement -fwrapv -Wno-address-of-packed-member -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-old-style-declaration -Wno-ignored-qualifiers -Wno-clobbered -Wno-missing-field-initializers -Wno-implicit-fallthrough -Wno-stringop-overflow -Wno-cast-function-type -Wtype-limits -Wshift-negative-value -Wshift-overflow=2 -Wduplicated-cond -Wnull-dereference
Built with multi-threading support (MAX_THREADS=64, default=3).
Available services :
        prometheus-exporter
