Hello, haproxy users!
Is it possible to limit the number of currently running HTTP requests per client (as opposed to the request rate), with “client” being represented by a session cookie?
For example, if I have 10 backend servers with maxconn 30 each, one client behind a slow line can issue 300 concurrent requests for something big, and exhaust all the backend connections.
I am fine with a client issuing requests as fast as possible, provided that it issues a next request only after the previous one has finished. Moreover, I don’t want requests of a malfunctioning client to be dropped, only queued somewhere.
I tried the following approach:
frontend myserver
capture cookie session= len 15 # for logging
stick-table type string len 8 size 100k store conn_cur expire 10m
http-request track-sc0 cookie(session)
default_backend trash-be
use_backend prime-be if { cookie("session") -m found } { src_conn_cur lt 5 }
backend trash-be
stick-table type string len 6 size 16k expire 10m
stick on cookie(session)
server worker01 10.0.0.101:443 maxconn 2
server worker10 10.0.0.110:443 maxconn 2
backend prime-be # same workers with higher maxconn:
server worker01 10.0.0.101:443 maxconn 30
server worker10 10.0.0.110:443 maxconn 30
I expect one session to have at most 4 running concurrent requests routed to prime-be, and the rest (should there be any) redirected to trash-be, where it would stick on the same backend server (at most two additional requests) and be queued otherwise.
The above apparently does not work - today I have seen one client issuing many 900+ seconds lasting download requests in paralllel, all being forwarded to prime-be for some reason, exhausting all the 300 connections.
One of the problems with the above approach is that it counts connections, not requests. So if the backends speak HTTP/1.1 only (as mine do) and the malfunctioning client issues many requests inside a single HTTP/2 connection, it still fills all the slots on prime-be, because it is a single connection.
However, I have checked the logs, and I see this also with HTTP/1.1 requests from one IP address and different source ports, so is not a problem of HTTP/2 requests inside a single connection only.
Is it possible to track running requests instead of src_conn_cur? Is there another approach how to limit in-flight requests per session?
Thanks,
-Yenya
