Hello all
I have a http frontend which goes via URL to a certain backend.
Now I want to achieve that the backend only takes a certain number of clients and otherwise redirects to the next one or displays an error status page.
So far I only found how to forward the new requests to the next server with a certain number of connections.
But it can be that several clients arrive over the same source ip. Therefore you would have to split the requests based on header or cookie
Can I get some help here?
Best regards
How does the configuration look like currently?
Hey sorry
Here is the config
log /dev/log local1 debug
log 127.0.0.1 len 8096 local2
log-send-hostname
maxconn 4096
ssl-default-bind-options no-sslv3 no-tlsv10 no-tlsv11
log-format {\"haproxy_clientIP\":\"%ci\",\"haproxy_clientPort\":\"%cp\",\"haproxy_dateTime\":\"%t\",\"haproxy_frontendNameTransport\":\"%ft\",\"haproxy_backend\":\"%b\",\"haproxy_serverN
ame\":\"%s\",\"haproxy_Tw\":\"%Tw\",\"haproxy_Tc\":\"%Tc\",\"haproxy_Tt\":\"%Tt\",\"haproxy_bytesRead\":\"%B\",\"haproxy_terminationState\":\"%ts\",\"haproxy_actconn\":%ac,\"haproxy_FrontendCurr
entConn\":%fc,\"haproxy_backendCurrentConn\":%bc,\"haproxy_serverConcurrentConn\":%sc,\"haproxy_retries\":%rc,\"haproxy_srvQueue\":%sq,\"haproxy_backendQueue\":%bq,\"haproxy_backendSourceIP\":\"
%bi\",\"haproxy_backendSourcePort\":\"%bp\",\"haproxy_statusCode\":\"%ST\",\"haproxy_serverIP\":\"%si\",\"haproxy_serverPort\":\"%sp\",\"haproxy_frontendIP\":\"%fi\",\"haproxy_frontendPort\":\"%
fp\",\"haproxy_capturedRequestHeaders\":\"%hr\",\"haproxy_httpRequest\":\"%r\"} #test
timeout connect 10000
errorfile 429 /etc/haproxy/errors/429.http
frontend http_frontend
capture request header Host len 30
capture request header User-Agent len 200
capture request header Referer len 800
capture request header X-Forwarded-For len 20
http-request add-header X-Forwarded-Host %[req.hdr(host)]
http-request add-header X-Forwarded-Server %[req.hdr(host)]
http-request add-header X-Forwarded-Port %[dst_port]
default_backend www-backend
backend www-backend
option httpchk HEAD / HTTP/1.1rnHost:localhost
backend letsencrypt-backend
frontend https_frontend
bind *:443 ssl crt /etc/haproxy/certs
tcp-request connection accept if { src -f /etc/haproxy/whitelist.lst }
use_backend 0000-webservice if { req.hdr(Host),regsub(:[0-9]+$,) -i webservice.example.com
balance source
server 0000-webservice01 10.0.0.1:80 check
server 0000-webservice02 10.0.0.2:80 check
Thank you
You configured balance source. Can you elaborate why you need source IP persistence? This goes against of what you are trying to achieve.
Understanding your exact application and backend server requirements is necessary to be able to make suggestion regarding the load-balancing.
My problem is that I do not know how to configure this.
I only found scenarios where I can limit the connections per second and not clients.
I would have to filter sessions, but I don’t know how this scenario could look like.
I want a maximum of 10 browsers to be able to connect to Server1 at the same time(e.g. 10.0.0.1) the next 10 to Server2(10.0.0.2)
With the current configuration I only have the limit on source IP, which doesn’t help me if multiple clients have the same public ip.
That’s wrong, with the current configuration are you not limiting by source IP. I think you have mixed up some of the concepts here.
First of all, I don’t think you need source IP persistence, so the first thing you should do, is remove the balance source configuration. It also seems a source of confusion in this case.
Since you are trying to keep connections to each server as low as possible, I’d suggest you go with source leastconn.
More about the balance keyword in the docs:
https://cbonte.github.io/haproxy-dconv/2.0/configuration.html#4.2-balance
On each server then, you’d add a maxconn 10 keyword, which will limit the amount of connections to a single server to 10, which also means there won’t be more than 10 transactions in flight towards this server. Which is what you would like to achieve in the end, right?
Your intention is to avoid having the server work on more than 10 requests simultaneously, correct?
I have the leastconn with maxconn on another service, this allows me to prevent the clients from switching between the servers.
I don’t care about the requests in my currently searched scenario, I really care about sessions.
I have 10 workstations and a public ip, which the workstations use to connect to my service.
I want to connect the first 5 workstations(or browsers) on the first server and each additional workstation on the second server.
Therefore I think that this can only be achieved with SESSIONID, Cookie or something else, but I didn’t find anything about it.
midas1989:
Then use balance first instead, and specify maxconn 10 for each server.
I think you need to explain what actual problem you are trying to solve, otherwise I’m pretty certain this is not gonna go anywhere.
