I have a strange problem with HTTP load balancing. The issue is that number of sessions on the www-https frontend is drastically different compared to its backend. Here is a screenshot from the stats page how it looks like:
Check the number of sessions on www-https (4934) and on events-backend-https (157). What is even stranger is that if I check the number of established connections on that HAProxy host to the backend servers (which are all listening on 8080), I get this:
[root@events-client-haproxy-01 ~]# ss -nta state established 'dport = 8080' | wc -l
1981
which is a lot more than 157 that HAProxy is reporting.
Other thing that is strange is that on that same frontend session rate is 222, while on the backends that session rate is 1009?
I pasted below the whole config, but the most relevant part is that keep-alive should be used, because it’s not disabled anywhere. Also because option prefer-last-server is set, those keep-alive connections should be reused on the servers. On the servers keep-alive timeout is set to be 30s, which is the same as on HAProxy.
log /dev/log local2
pidfile /var/run/haproxy.pid
nbthread 6
maxconn 300000
stats socket /var/lib/haproxy/stats expose-fd listeners mode 0777 level admin
server-state-file /var/lib/haproxy/server-state
maxconn 2000
backlog 4000
retries 2
option dontlog-normal
timeout http-request 5s
timeout queue 5s
timeout client 15m
timeout server 15m
timeout http-keep-alive 30s
timeout check 5s
frontend tcp
bind :7705
maxconn 200000
default_backend events-backend-tcp
frontend www-http
bind :80 alpn h2,http/1.1
maxconn 1000
acl is_trace_track method TRACE TRACK
http-request deny if is_trace_track
http-response set-header Strict-Transport-Security max-age=15768000
default_backend events-backend-https
frontend www-https
bind :443 ssl crt /etc/pki/tls/private/events.example.com.pem alpn h2,http/1.1
maxconn 200000
balance static-rr
option tcp-check
default-server inter 4s rise 2 fall 4 maxconn 50000 check agent-check agent-port 8081
server events-client-app-01 events-client-app-01:7705
server events-client-app-02 events-client-app-02:7705
server events-client-app-03 events-client-app-03:7705
server events-client-app-04 events-client-app-04:7705
server events-client-app-05 events-client-app-05:7705
balance static-rr
option httpchk GET /api/v1/health-check/simple-check
server events-client-app-01 events-client-app-01:8080
server events-client-app-02 events-client-app-02:8080
server events-client-app-03 events-client-app-03:8080
server events-client-app-04 events-client-app-04:8080
server events-client-app-05 events-client-app-05:8080
bind :9000
stats hide-version
stats uri /
stats refresh 10s
Any ideas why is this happening?
