Hi! I hope you’re all doing well
I’ve got a HAProxy setup which runs on the edge of our cluster brilliantly. I’ve built in failover using PCS and it’s been absolutely solid.
Within our cluster we’ve traditionally had X number of nodes, each referenced in the configuration as below. The proxy also performs TLS termination (hence the HTTP mode rather than TCP’ing it through).
backend web
option tcp-check
# default-server check-send-proxy send-proxy check port 2443 fall 3 rise 2
default-server port 80 check port 443 fall 3 rise 2 send-proxy
reqadd X-Forwarded-Port:\ 443
server web01 192.168.1.20:80
server web02 192.168.1.21:80
server web03 192.168.1.22:80
In the above instance, I know that we have three nodes on their respective IP’s, .20, .21 & 22. However, we are now looking at a new solution which can spawn nodes at any point and can be on any address being .20 - .50. Is there an easy/suggested way to handle this use case?
I’m imagining I’ll still have to configure each node like the above configuration, but we’d expect a majority of them to be appear offline. Is there a way to not show down status but mark the out nodes as backups, and then when they come online automatically make them an active node?
What I ideally don’t want is a sea of red on the status page as most of the IP’s are unallocated and unresponsive.
Thanks!
