I am running an HAProxy version 2.0.13-2ubuntu0.1.
When I perform a reload on HAProxy to load new configuration, I am aware, that this spawns a new process and therefore (some) stats are reset.
But for me, the old process keeps running, and especially keeps holding “already present” connections.
This brings me in the situation, where the stats page and the stats socket tell me, there are eg. 5 established connections, but in reality, there are >100 connections established in the “old” process.
Is there a way to:
- Make the new process also showing the existing connections for the old one, or
- Have the new process taking over already existing connections, or
- somehow still access the stats socket for that old process?
I would be totally fine, gathering my data from multiple stats sockets, if due to a reload, multiple processes are running. But sadly I seem to only get one socket and only the data from the newest process.
My config:
# Managed by chef
log 127.0.0.1:9001 local0 notice
log 127.0.0.1:9001 local1 info
maxconn 100000
external-check
spread-checks 5
stats socket /var/run/haproxy/admin.sock mode 660 expose-fd listeners level admin
stats socket /var/run/haproxy/haproxy.sock expose-fd listeners mode 666 level user
nbproc 1
nbthread 4
cpu-map 1/all 0-1
tune.bufsize 524288
timeout client 600s
timeout server 600s
timeout check 250
listen stats # Define a listen section called "stats"
bind 127.0.0.1:443 ssl crt /etc/ssl/private/certificate.pem alpn http/1.1
bind 127.0.0.1:80
acl AUTH http_auth(statsuser)
stats http-request auth unless AUTH
stats enable # Enable stats page
# stats hide-version # Hide HAProxy version
stats uri / # Stats URI
stats admin if TRUE
maxconn 50
listen MyBackend
bind 10.0.0.18:188
timeout client 8h
timeout server 8h
option external-check
external-check command /var/lib/haproxy/checks/myCheck.sh
timeout check 500ms
default-server inter 1s
server node1.int 10.0.0.25:188 check
Thanks a lot in advance
