I have in my conf the lua module for the CORS policy it look like this.
I use this Enabling CORS in HAProxy - HAProxy Technologies
lua-load /etc/haproxy/cors.lua
frontend https_in
bind *:80 v4v6
bind *:443 v4v6 ssl crt /etc/ssl/certs/cert.pem alpn h2,http/1.1
acl http ssl_fc,not
http-request redirect scheme https if http
# Remove a response header
http-response del-header X-Powered-By
######## START CORS ########
http-request lua.cors "*" "api.domain.com auth.domain.com" "*"
http-response lua.cors
######### END CORS #########
If i activate the CORS module i don’t have the CORS policy error but one of my URL is rewrite in a GET call
Before activating the module:
https://api.domain.com/login_check/
After with the module:
https://api.domain.comlogin_check/
missing slash
I don’t understand what is the reason why it remove it.
Thank you for your time and help,
