Trying to enable CORS on HAPROXY using lua but getting error
I’m trying to enable CORS on HAPROXY using the the lua library but getting the below warnings when I start the HAPROXY service which looks as if my CORS config rules will be ignored
Apr 21 14:13:16 haproxyobvtest haproxy[3697]: [NOTICE]   (3697) : path to executable is /usr/sbin/haproxy
Apr 21 14:13:16 haproxyobvtest haproxy[3697]: [WARNING]  (3697) : config : parsing [/etc/haproxy/haproxy.cfg:27] : 'option httplog' not usable with frontend 'LoadBalancer' (needs>
Apr 21 14:13:16 haproxyobvtest haproxy[3697]: [WARNING]  (3697) : config : 'http-request' rules ignored for frontend 'LoadBalancer' as they require HTTP mode.
Apr 21 14:13:16 haproxyobvtest haproxy[3697]: [WARNING]  (3697) : config : 'http-response' rules ignored for frontend 'LoadBalancer' as they require HTTP mode.
Apr 21 14:13:16 haproxyobvtest haproxy[3697]: [NOTICE]   (3697) : New worker (3699) forked
Apr 21 14:13:16 haproxyobvtest haproxy[3697]: [NOTICE]   (3697) : Loading success.
Apr 21 14:13:16 haproxyobvtest systemd[1]: Started HAProxy Load Balancer.
Below is my haproxy.cfg
    lua-load /etc/opt/rh/rh-haproxy18/haproxy/cors.lua
    log /dev/log    local0
    log /dev/log    local1 notice
    stats socket /run/haproxy-admin.sock mode 660 level admin expose-fd listeners
    mode    http
    option  httplog
    option  dontlognull
    timeout client  50000
    timeout server  50000
frontend LoadBalancer
    bind *:443
    default_backend backend_servers
    http-request lua.cors "GET,PUT,POST,OPTIONS" "*" "*"
    http-response lua.cors
    option tcpka
    option tcp-check
    server 172.18.18.132 172.18.18.132:31811 check
    server 172.18.18.133 172.18.18.133:31811 check
    server 172.18.18.134 172.18.18.134:31811 check
    server 172.18.18.135 172.18.18.135:31811 check
    server 172.18.18.136 172.18.18.136:31811 check
    server 172.18.18.137 172.18.18.137:31811 check
    server 172.18.18.138 172.18.18.138:31811 check
    server 172.18.18.139 172.18.18.139:31811 check
    server 172.18.18.140 172.18.18.140:31811 check
    server 172.18.18.141 172.18.18.141:31811 check
    bind :9000 # Listen on localhost:9000
    stats enable  # Enable stats page
    stats hide-version  # Hide HAProxy version
    stats realm Haproxy\ Statistics  # Title text for popup window
    stats uri /haproxy_stats  # Stats URI
My cors.lua file I just took from below gitrepo without editing
