I try the first topic for Lua sharing. I propose to discuss about stats aggregation between related (or not) HAProxy process.
there is the link to the sources:
http://www.arpalert.org/haproxy-scripts.html#stats
stats = {}
-- Configuration
stats.conf = {} -- Lists all known haproxy, the index is the friendly
-- name of the instance.
-- internal shared vars
stats.agg = {} -- contains the aggregated data
stats.servers = {} -- List of the last data retrieved by server
stats.lookup = {} -- contains a lookup for used keys.
HAProxy stats compatibility array. Alle the metrics are not
used with all the parts (backend, frontend, servers or
listener. This array permit to give a useless element,
and gives an aggregation method.
1 : type 0: frontend
2 : type 1: backend
3 : type 2: server
4 : type 3: listener
5 : type of data:
"string" : string.
"gauge" : integer, value.
"counter" : integer, alway monotonic, increse with the time spent.
"time" : integer, time ellapsed.
6 : aggregation type:
"first" : keep the first value
"add" : add all values
"cat" : catenate the values, separed by a "/"
"avg" : perform the average of the values
stats.values = {
-- 1 2 3 4 5 6
["pxname"] = { "1", "1", "1", "1", "string", "first"},
["svname"] = { "1", "1", "1", "1", "string", "first"},
["qcur"] = { " ", "1", "1", " ", "gauge", "add" },
["qmax"] = { " ", "1", "1", " ", "gauge", "add" },
["scur"] = { "1", "1", "1", "1", "gauge", "add" },
["smax"] = { "1", "1", "1", "1", "gauge", "add" },
["slim"] = { "1", "1", "1", "1", "gauge", "add" },
["stot"] = { "1", "1", "1", "1", "counter", "add" },
["bin"] = { "1", "1", "1", "1", "counter", "add" },
["bout"] = { "1", "1", "1", "1", "counter", "add" },
["dreq"] = { "1", "1", " ", "1", "counter", "add" },
["dresp"] = { "1", "1", "1", "1", "counter", "add" },
["ereq"] = { "1", " ", " ", "1", "counter", "add" },
["econ"] = { " ", "1", "1", " ", "counter", "add" },
["eresp"] = { " ", "1", "1", " ", "counter", "add" },
["wretr"] = { " ", "1", "1", " ", "counter", "add" },
["wredis"] = { " ", "1", "1", " ", "counter", "add" },
["status"] = { "1", "1", "1", "1", "string", "cat" },
["weight"] = { " ", "1", "1", " ", "gauge", "add" }, -- maybe more complex
["act"] = { " ", "1", "1", " ", "gauge", "add" },
["bck"] = { " ", "1", "1", " ", "gauge", "add" },
["chkfail"] = { " ", " ", "1", " ", "counter", "add" },
["chkdown"] = { " ", "1", "1", " ", "counter", "add" },
["lastchg"] = { " ", "1", "1", " ", "time", "avg" },
["downtime"] = { " ", "1", "1", " ", "time", "avg" },
["qlimit"] = { " ", " ", "1", " ", "gauge", "add" },
["pid"] = { "1", "1", "1", "1", "gauge", "cat" },
["iid"] = { "1", "1", "1", "1", "gauge", "cat" },
["sid"] = { " ", " ", "1", "1", "gauge", "cat" },
["throttle"] = { " ", " ", "1", " ", "gauge", "avg" },
["lbtot"] = { " ", "1", "1", " ", "counter", "add" },
["tracked"] = { " ", " ", "1", " ", "counter", "add" },
["type"] = { "1", "1", "1", "1", "gauge", "first"},
["rate"] = { "1", "1", "1", " ", "gauge", "add" },
["rate_lim"] = { "1", " ", " ", " ", "gauge", "add" },
["rate_max"] = { "1", "1", "1", " ", "gauge", "add" },
["check_status"] = { " ", " ", "1", " ", "string", "cat" },
["check_code"] = { " ", " ", "1", " ", "string", "cat" },
["check_duration"]= { " ", " ", "1", " ", "time", "cat" },
["hrsp_1xx"] = { "1", "1", "1", " ", "counter", "add" },
["hrsp_2xx"] = { "1", "1", "1", " ", "counter", "add" },
["hrsp_3xx"] = { "1", "1", "1", " ", "counter", "add" },
["hrsp_4xx"] = { "1", "1", "1", " ", "counter", "add" },
["hrsp_5xx"] = { "1", "1", "1", " ", "counter", "add" },
["hrsp_other"] = { "1", "1", "1", " ", "counter", "add" },
["hanafail"] = { " ", " ", "1", " ", "string", "cat" },
["req_rate"] = { "1", " ", " ", " ", "gauge", "add" },
["req_rate_max"] = { "1", " ", " ", " ", "gauge", "add" },
["req_tot"] = { "1", " ", " ", " ", "counter", "add" },
["cli_abrt"] = { " ", "1", "1", " ", "counter", "add" },
["srv_abrt"] = { " ", "1", "1", " ", "counter", "add" },
["comp_in"] = { "1", "1", " ", " ", "counter", "add" },
["comp_out"] = { "1", "1", " ", " ", "counter", "add" },
["comp_byp"] = { "1", "1", " ", " ", "counter", "add" },
["comp_rsp"] = { "1", "1", " ", " ", "counter", "add" },
["lastsess"] = { " ", "1", "1", " ", "time", "avg" },
["last_chk"] = { " ", " ", "1", " ", "string", "cat" },
["last_agt"] = { " ", " ", "1", " ", "string", "cat" },
["qtime"] = { " ", "1", "1", " ", "gauge", "avg" },
["ctime"] = { " ", "1", "1", " ", "gauge", "avg" },
["rtime"] = { " ", "1", "1", " ", "gauge", "avg" },
["ttime"] = { " ", "1", "1", " ", "gauge", "avg" },
["agg"] = { "1", "1", "1", "1", "string", "cat" },
-- csv header order
stats.csv = {
"pxname", "svname", "qcur", "qmax", "scur", "smax",
"slim", "stot", "bin", "bout", "dreq", "dresp",
"ereq", "econ", "eresp", "wretr", "wredis", "status",
"weight", "act", "bck", "chkfail", "chkdown", "lastchg",
"downtime", "qlimit", "pid", "iid", "sid", "throttle",
"lbtot", "tracked", "type", "rate", "rate_lim", "rate_max",
"check_status", "check_code", "check_duration", "hrsp_1xx", "hrsp_2xx", "hrsp_3xx",
"hrsp_4xx", "hrsp_5xx", "hrsp_other", "hanafail", "req_rate", "req_rate_max",
"req_tot", "cli_abrt", "srv_abrt", "comp_in", "comp_out", "comp_byp",
"comp_rsp", "lastsess", "last_chk", "last_agt", "qtime", "ctime",
"rtime", "ttime", "agg"
get_stats(uri, mode)
uri is the location of the required resources. It understand the following
forms:
* http://<ip>[:<port>]/<path>
* socket://<path>
This function returns a hash table with the frontends ans backend
hierarchically sorted. In error case, send an error using the"error"
function and doesn't returns.
stats.get_stats = function(uri)
local pathpos
local path
local addr
local msg
local s
local csv = {}
local line = {}
local pos1
local pos2
local typeidx
local typepx
local res
local i
local t
-- uri must start with http:// or socket://
if string.sub(uri, 1, 7) == "http://" then
mode = 1
addr = string.sub(uri, 8)
elseif string.sub(uri, 1, 9) == "socket://" then
mode = 2
addr = string.sub(uri, 10)
else
error("'uri' must starts with 'http://', we found '" ..
tostring(string.sub(uri, 1, 7)) .. "'")
end
-- mode 1: sends http request
if mode == 1 then
-- separates ip:port from the path
local pathpos = string.find(addr, "/")
if (pathpos == nil) then
path = "/"
else
path = string.sub(addr, pathpos)
end
addr = string.sub(addr, 1, pathpos)
-- send request
s = core.tcp()
s:connect(addr)
s:send("GET " .. path .. " HTTP/1.0\r\nHost: " .. addr .. "\r\n\r\n");
-- read response, remove headers
while true do
msg = s:receive("*l")
msg = string.gsub(msg, "\r", "")
msg = string.gsub(msg, "\n", "")
if msg == "" then break end
end
-- read CSV
msg = s:receive("*a")
if msg == nil then
error("cannot retrieve stats from " .. uri)
end
-- close conection
s:close()
-- mode 2: sens stats request
elseif mode == 2 then
-- send request
s = core.tcp()
s:connect("unix@" .. addr)
s:send("show stat -1 15 -1\n");
-- read CSV
if msg == nil then
end
-- close conection
s:close()
end
-- removes \r
while true do
-- read first value. expects
if string.sub(msg, 1, 1) == '"' then
-- read a simple value terminated by '"', escapes the '""'.
else
-- read a simple value terminated by "," or "\n"
pos1 = string.find(msg, ",")
pos2 = string.find(msg, "\n")
if pos1 == nil then pos1 = string.len(msg) end
if pos2 == nil then pos2 = string.len(msg) end
if pos2 < pos1 then pos1 = pos2 end
table.insert(line, string.sub(msg, 1, pos1 - 1))
-- if the separator is a newline
if string.sub(msg, pos1, pos1) == "\n" then
table.insert(csv, line)
line = {}
end
msg = string.sub(msg, pos1 + 1) -- eat the cell
end
-- reak process if the csv message is empty
end
-- transform value array to object array
local hdr = {}
local obj = {}
for i, t in pairs(csv) do
if type(t[1]) == "string" and t[1] == "# pxname" then
t[1] = "pxname"
hdr = t
-- look for the type idx
for i,v in pairs(hdr) do
if v == "type" then
typeidx = i
break
end
end
else
-- create new array that is a mix between
-- column name and values. Clean the useless
-- values.
local h = {}
if t[typeidx] ~= nil then
typepx = tonumber(t[typeidx]) + 1
for i,v in pairs(t) do
if hdr[i] ~= "" then
if stats.values[hdr[i]] ~= nil then
if stats.values[hdr[i]][typepx] == "1" then
if stats.values[hdr[i]][5] == "gauge" or
stats.values[hdr[i]][5] == "counter" or
stats.values[hdr[i]][5] == "time" then
h[hdr[i]] = tonumber(v)
else
h[hdr[i]] = v
end
end
end
end
end
end
table.insert(obj, h)
end
end
-- define the array object
res = {}
res['frontends'] = {}
res['backends'] = {}
-- process all the frontends
for i, t in pairs(obj) do
if t["type"] == 0 then -- frontend
res['frontends'][t["pxname"]] = t
res['frontends'][t["pxname"]]["listeners"] = {}
elseif t["type"] == 1 then -- backend
res['backends'][t["pxname"]] = t
res['backends'][t["pxname"]]["servers"] = {}
end
end
-- process all the backends
if t["type"] == 2 then -- server
res['backends'][t["pxname"]]["servers"][t["svname"]] = t
elseif t["type"] == 3 then -- listener
res['frontends'][t["pxname"]]["listeners"][t["svname"]] = t
end
end
return res
end
stats.merge_agg = function(stats, mode)
local k
local v
local res
local c
-- first
if mode[6] == "first" then
for k, v in pairs(stats) do
res = stats[k]
break
end
-- add
elseif mode[6] == "add" then
res = 0
res = res + stats[k]
end
-- catenate
elseif mode[6] == "cat" then
res = ""
if res == "" then
res = tostring(stats[k])
else
res = res .. "/" .. tostring(stats[k])
end
end
-- average
elseif mode[6] == "avg" then
res = 0
c = 0
c = c + 1
end
if c > 0 then
res = res / c
end
end
return res;
end
stats.merge_stats = function(stats_array)
local res;
local list;
local k
local v
local val
local srv
local frt
local bck
local lis
local stat
-- destination struct
res = {}
-- fill the destination
for srv, stat in pairs(stats_array) do
if stat['frontends'] ~= nil then
for frt, val in pairs(stat['frontends']) do
if res['frontends'][frt] == nil then
res['frontends'][frt] = {}
res['frontends'][frt]['listeners'] = {}
end
if stat['frontends'][frt]['listeners'] ~= nil then
for lis, val in pairs(stat['frontends'][frt]['listeners']) do
end
if res['frontends'][frt]['listeners'] == nil then
end
if res['frontends'][frt]['listeners'][lis] == nil then
res['frontends'][frt]['listeners'][lis] = {}
end
end
end
end
end
if stat['backends'] ~= nil then
for frt, val in pairs(stat['backends']) do
if res['backends'][frt] == nil then
res['backends'][frt] = {}
res['backends'][frt]['servers'] = {}
end
if stat['backends'][frt]['servers'] ~= nil then
for srv, val in pairs(stat['backends'][frt]['servers']) do
end
if res['backends'][frt]['servers'] == nil then
end
if res['backends'][frt]['servers'][srv] == nil then
res['backends'][frt]['servers'][srv] = {}
end
end
end
end
end
end
-- data aggregation
-- frontends
for frt, val in pairs(res['frontends']) do
for prop, mode in pairs(stats.values) do
if mode[1] == "1" then
-- build list of frontends
list = {}
for k, v in pairs(stats_array) do
if stats_array[k]['frontends'] and
stats_array[k]['frontends'][frt] and
stats_array[k]['frontends'][frt][prop] then
list[k] = stats_array[k]['frontends'][frt][prop]
end
end
-- aggregation values
res['frontends'][frt][prop] = stats.merge_agg(list, mode)
end
end
list = ""
if stats_array[k]['frontends'][frt] ~= nil then
if list == "" then
list = k
else
list = list .. "/" .. k
end
end
end
res['frontends'][frt]["agg"] = list
-- listeners
for lis, val in pairs(res['frontends'][frt]['listeners']) do
if mode[4] == "1" then
list = {}
if v['frontends'][frt] and
v['frontends'][frt]['listeners'] and
v['frontends'][frt]['listeners'][lis] and
v['frontends'][frt]['listeners'][lis][prop] then
list[k] = v['frontends'][frt]['listeners'][lis][prop]
end
end
res['frontends'][frt]['listeners'][lis][prop] = stats.merge_agg(list, mode)
end
end
list = ""
if stats_array[k]['frontends'][frt] and
stats_array[k]['frontends'][frt]['listeners'] and
stats_array[k]['frontends'][frt]['listeners'][lis] then
if list == "" then
list = k
else
end
end
end
res['frontends'][frt]['listeners'][lis]["agg"] = list
end
end
-- backends
for bck, val in pairs(res['backends']) do
if mode[2] == "1" then
list = {}
if stats_array[k]['backends'] and
stats_array[k]['backends'][bck] and
stats_array[k]['backends'][bck][prop] then
list[k] = stats_array[k]['backends'][bck][prop]
end
end
res['backends'][bck][prop] = stats.merge_agg(list, mode)
end
end
list = ""
if stats_array[k]['backends'][bck] ~= nil then
if list == "" then
list = k
else
end
end
end
res['backends'][bck]["agg"] = list
-- servers
for srv, val in pairs(res['backends'][bck]['servers']) do
if mode[3] == "1" then
list = {}
if v['backends'][bck] and
v['backends'][bck]['servers'] and
v['backends'][bck]['servers'][srv] and
v['backends'][bck]['servers'][srv][prop] then
list[k] = v['backends'][bck]['servers'][srv][prop]
end
end
res['backends'][bck]['servers'][srv][prop] = stats.merge_agg(list, mode)
end
end
list = ""
if stats_array[k]['backends'][bck]['servers'][srv] ~= nil then
if list == "" then
list = k
else
end
end
end
res['backends'][bck]['servers'][srv]["agg"] = list
end
end
return res
end
stats.tocsv = function(msg)
if msg == nil then return "" end
return tostring(msg)
end
-- This function is an applet thats accept and HTTP request
-- and return a aggregated CSV
stats.csv_service = function(applet)
local frt
local bck
local srv
local lis
local val1
local val2
local k
local i
local msg
msg = "# "
for i, k in ipairs(stats.csv) do
msg = msg .. k .. ","
end
msg = msg .. "\n"
for frt, val1 in pairs(stats.agg['frontends']) do
msg = msg .. stats.tocsv(val1[k]) .. ","
end
msg = msg .. "\n"
for lis, val2 in pairs(val1['listeners']) do
msg = msg .. stats.tocsv(val2[k]) .. ","
end
msg = msg .. "\n"
end
end
for bck, val1 in pairs(stats.agg['backends']) do
end
msg = msg .. "\n"
for srv, val2 in pairs(val1['servers']) do
end
msg = msg .. "\n"
end
end
applet:add_header("content-length", tostring(msg:len()));
applet:set_status(200)
applet:start_response()
applet:send(msg)
end
-- The following function gets and merge all the known haproxy
-- stats each second.
stats.update = function()
local k
local v
local srv = {}
while true do
for k, v in pairs(stats.conf) do
srv[k] = stats.get_stats(v)
end
local g = stats.merge_stats(srv)
stats.servers = srv;
stats.agg = g
core.sleep(1)
end
end
-- register general fetches to get the merged values
-- syntax is:
-- ["f" | "b"] ":" <fe/be name> ":" <metrix>
-- ["f" | "b"] ":" <fe/be name> ":" [ <server> | <listener> ] ":" <metrix>
-- example:
-- f:bck_webfarm:qcur
-- f:bck_webfarm:server1:qcur
stats.process_key = function(key)
local path = {}
local p = key
local pos
local febe = 0
if stats.lookup[key] ~= nil then
return stats.lookup[key]
end
-- must start with "f:" or "b:"
if p:sub(1, 2) == "f:" then
table.insert(path, "frontends")
febe = 0
elseif p:sub(1, 2) == "b:" then
table.insert(path, "backends")
febe = 1
else
error("the agg key '" .. key .. "' is invalid")
end
p = p:sub(3)
-- look for the next part, search a mandatory ":"
pos = p:find(":")
if pos == nil then
end
table.insert(path, p:sub(1, pos - 1))
p = p:sub(pos + 1)
-- look for the next part, search for a ":" or the end.
pos = p:find(":")
if pos == nil then
table.insert(path, p)
stats.lookup[key] = path
return path
end
if febe == 0 then
table.insert(path, "listeners")
else
table.insert(path, "servers")
end
p = p:sub(pos + 1)
-- stores the last part
table.insert(path, p:sub(1, -1))
-- index and return the result
return path
end
stats.fetch = function(txn, name)
local w
local path
local i
local v
local tab
-- perform a lookup
path = stats.process_key(name)
tab = stats.agg
for i, v in pairs(path) do
if tab[v] == nil then
error("key '" .. name .. "' doesn't exists (or not yet exists)")
end
tab = tab[v]
end
return tab
end
-- ["h1"] = "http://127.0.0.1:10002/;csv",
-- ["h2"] = "socket:///tmp/haproxy",
stats.add = function(name, uri)
stats.conf[name] = uri
end
core.register_service("stats", "http", stats.csv_service)
core.register_fetches("stats", stats.fetch)
core.register_task(stats.update)
