These may be bugs, but I’m more inclined to believe they are just some kind of configuration assumptions we’re making poorly.
We’ve had sporadic reports from customers using our file-sharing service (think large and small files ala Dr*pbox) that downloads get “corrupted” – more specifically, the last few bytes or blocks don’t get transferred. This occurred when we had HTTP/2.0 enabled on HAPROXY. Direct to the Apache server backends, this problem doesn’t present. Ok. Disable HTTP/2.0. move on.
Next, we get reports that there is some kind of (new) upload challenge with HTTP/1.1 running on HAPROXY.We haven’t changed our config other than disabling 2.0. Remove HAPROXY (go direct to Apache), problem disappears.
So now I’m wondering if we have our timeouts or buffers or something set strangely either on the haproxy server(s) themselves. We are actively working on creating reproducibility of the issue, so this is just a shot in the dark before that.
Anything from a few Kbytes to 10+GB of transfers in either direction for several hundreds of users per server. Latencies from 2ms up to 300ms or more depending on where in the world they are (or that plus cell phones or satellite).
In some cases people are transferring files over 100G, but that could be hitting the 12 hour window.
Here is the config:
maxconn 100000
stats socket /run/haproxy/admin.sock mode 777 level admin expose-fd listeners
nbproc 1
nbthread 8
hard-stop-after 12h
tune.bufsize 65536
tune.h2.initial-window-size 4096000
option log-separate-errors
timeout client 12h
timeout server 12h
timeout connect 20s
log-format "%ci:%cp [%tr] %ft %b/%s %TR/%Tw/%Tc/%Tr/%Ta %ST %B %CC %CS %tsc %ac/%fc/%bc/%sc/%rc %sq/%bq %hr %hs %{+Q}r %sslc"
listen statsend
bind 127.0.0.1:9000
stats hide-version
stats scope .
stats uri /haproxy-stats?stats
cache objects
total-max-size 1024
max-object-size 2560000
max-age 86400
frontend cp.xxx.com
bind *:80 tcp-ut 300s
bind :::80 tcp-ut 300s
bind *:443 ssl crt /etc/apache2/sites-available/xxx.com/ssl/le/ssl-certs.pem ssl-min-ver TLSv1.2 alpn http/1.1 tcp-ut 300s
bind :::443 ssl crt /etc/apache2/sites-available/xxx.com/ssl/le/ssl-certs.pem ssl-min-ver TLSv1.2 alpn http/1.1 tcp-ut 300s
maxconn 50000
compression algo gzip
compression type text/html text/plain text/javascript application/javascript application/xml text/css
timeout client 8h
timeout http-keep-alive 60s
timeout http-request 60s
timeout client-fin 60s
http-request cache-use objects
http-response cache-store objects
capture request header Referrer len 64
capture request header Content-Length len 10
http-request add-header Strict-Transport-Security max-age=15768000
default_backend nodes
backend nodes
hash-type consistent
fullconn 40000
timeout check 3000
option httpchk GET /index.php
http-check expect status 200
retry-on empty-response conn-failure
option log-health-checks
cookie WSRVID insert indirect nocache maxidle 30m maxlife 24h
server www3.xxx.com 127.0.0.5:443 check check-ssl ssl force-tlsv13 verify none sni ssl_fc_sni allow-0rtt alpn http/1.1 cookie s3 maxconn 10000 check-alpn http/1.1 tcp-ut 300s
server www4.xxx.com 127.0.0.6:443 check check-ssl ssl force-tlsv13 verify none sni ssl_fc_sni allow-0rtt alpn http/1.1 cookie s4 maxconn 10000 check-alpn http/1.1 tcp-ut 300s
server www5.xxx.com 127.0.0.7:443 check check-ssl ssl force-tlsv13 verify none sni ssl_fc_sni allow-0rtt alpn http/1.1 cookie s5 maxconn 10000 check-alpn http/1.1 tcp-ut 300s
server www6.xxx.com 127.0.0.8:443 check check-ssl ssl force-tlsv13 verify none sni ssl_fc_sni allow-0rtt alpn http/1.1 cookie s6 maxconn 10000 check-alpn http/1.1 tcp-ut 300s
Thanks in advance!
