I have installed HAproxy on two vagrant VM in virtualbox (both debian buster, on bridged network connection) and has setup (installed on the VM) keepalived to manage a single VIP. I am running two nginx docker containers on each machine. When I use the IP address for the ‘backend’ everything works as it should.
When I use the hostname of the container HAproxy says
Nov 16 21:12:05 buster haproxy[24426]: [ALERT] 320/211205 (24426) : parsing [/etc/haproxy/haproxy.cfg:48] : 'server server1' : could not resolve address 'nginx1'.
Nov 16 21:12:05 buster haproxy[24426]: [ALERT] 320/211205 (24426) : parsing [/etc/haproxy/haproxy.cfg:49] : 'server server2' : could not resolve address 'nginx2'.
Docker setup
docker network create web-net
docker run --name nginx1 --hostname nginx1 --network web-net -d nginxdemos/hello
docker run --name nginx2 --hostname nginx2 --network web-net -d nginxdemos/hello
HAproxy configuration
resolvers docker
nameserver dns 127.0.0.11:53
frontend http-in
bind 192.168.100.200:80 # VIP
default_backend servers
backend servers
server server1 nginx1:8080 check resolvers docker resolve-prefer ipv4
server server2 nginx2:8080 check resolvers docker resolve-prefer ipv4
If I put the IP address of the nginx containers, instead of name then everything is fine.
Can someone point me why the name resolution is not working correctly ? I tried the docker interface address. Any point to debug it correctly ?
Thank you.
