Greetings,
I’m using HAproxy for his capacity to do redirection of ports in a large range.
Basically, I have this type of configuration :
frontend haproxy_front
bind :6000-8000
default_backend mee
backend redirect_sas
server mee x.x.x.x
And I need to create multiple frontend and backend with an allocation of 2000 ports by backend. But one specifity : ports must be also redirected.
Which mean by example in my haproxy, ports 1-2000 are going to my machine 1 into it ports 1-2000, but ports in the range 2001 to 4000 must go to my machine 2 into ports 1-2000.
I’ve searched and I haven’t found basic solution or functionality into HAproxy for this case.
So my first question is “It is possible ?”. And the second : “They are a point about that in the documentation ?”.
Regards,
Darcosion.
